Question about Mitsubishi WD Televison & Video
Mitsubishi dpl code 61
61
2 Suggested Answers
  • 11800 Answers
SOURCE: RED LIGHT IN THE BACK
The light comes from the power source and signals that it has been shut down in emergency mode. This happens when another component of the tv fails and it starts acting like a short - the protection system of the power source gets triggered and the source if forcefully shut down to protect it and the rest of the components of the tv.
If the damaged part isn't a critical one the main control processor of the tv should still get enough power to approximatively identify the failed part and issue an error code thru the status light on the front - it would blink in a very defined way. But since you don't see that it means that the damage is indeed extensive and the only way to see what is wrong is to open the tv and test it - a job for an experienced electronics repair man. You must call one and in the mean time unplug the tv from the mains.
Posted on May 11, 2011
Mitsubishi DPL TV model wd73c8, serial 100759. The tv will not turn on & has a solid red light in status.
Try to turn it on manually by the power switch - not by using the remote control. Try to unplug it for an hour or more to discharge the power system, then try again.
Aug 02, 2016 | Mitsubishi Televison & Video
Mitsubishi Wd-73638 code 6 red 1 yellow not sure what that is please help
No error code 61 listed, only a 66 error code which indicates lamp issues:
66
A) Lamp did not turn on at P-ON sequence... Check CJ4 circuitry
B) No Lamp Inserted............... No Lamp inserted
C) Disconnected cable between ballast and lamp.... HV connection or lead wire to lamp.
D) Lamp-Enable goes to PWB-MAIN but not to Ballast....Lamp Cartridge Failure
for lamp see the following web site: http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73638
recommend using the manufacture part# as many replacements for Mitsubishi will not work.
May 08, 2015 | Mitsubishi Televison & Video
Mitsubishi error code DLP TV
CONTACT MITSUBISHI TECH SUPPORT
Jan 31, 2014 | Televison & Video
Need the DPL or CODE for Motorola RDV2020
The RDV2020 is programmable to many different PL and/or DPL codes. Here is a link to the manual: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
You can read about reprogramming codes pages 36-44. Or simply reading out the code on page 40.
Best regards.
Aug 13, 2011 | Motorola Mobility RDV2020 RDX Series On...
I have a 2007 73" Mitsibishi 1080P DPL HDTV. I am
this problem should be reported to the shop from where u havebrought it
Mar 31, 2011 | Mitsubishi Televison & Video
Vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
Apr 10, 2009 | Epson Printer
Tone squelch
Here is a link to download the user manual for the GP68 http://safemanuals.com/user-guide-instructions-owner-manual/MOTOROLA/GP68%20RADIO%20TRANSMITTER-_E
On your first radio, the one we've been discussing, I believe you have the DPL code set incorrectly. Your radio will go up to the number 126, but this is not the DPL code's number. It is simply a numbering system.
If I read the chart correctly:
DPL 205 equals the number 072.
DPL 023 equals the number 043.
Disclaimer: This numbering system listed in the user guide does not follow any common numbering system. I have other TPL/DPL charts which differ. The above reference is only based on what I have read in the user guide.
I am confident if your radio worked previously at another job site, using other frequencies/PL codes, that your only issue at this time is programming.
As for your unlock issue on the other GP68. Your radio may be in need of repair. The internal button is possibly wornout or has been depressed too far, and is bent on the board beyond the point of functioning.
Sep 25, 2008 | Motorola Radio Communications
2104 bell south
You may have one of them set to the wrong DPL code. Most FRS radios have a channel number and another number that corresponds to a DPL code. Try looking in your owners manual for this feature it may be known under a different description as each company calls it different things. DPL, PL, private code, user code etc.
Jul 24, 2008 | BellSouth 1040 2-Way Radio
Scanner codes
46.14000 KEG324 BM 1 Fire Dispatch FM 46.26000 KEG324 M 2 Fireground FM 46.30000 KEG324 BM Fireground FM 45.88000 KEG324 BM Fire Statewide Inter-County Mutual Aid FM 151.48250 KEG324 BM 331 DPL 1 EMS FM 154.79250 KEG324 BM 331 DPL 2 EMS FM 155.89500 KEG324 B 331 DPL 3 EMS Dispatch Only FM 155.91000 159.25500 WNMH370 RM 123.0 PL Sheriff FM 155.37000 KEG324 B Sheriff/Police Statewide Intercity FM 45.32000 WNBT946 BM Civil Defense FM 45.40000 WNBT946 BM Civil Defense FM 453.81250 458.81250 WQGH734 RM Communications Van FM 465.52500 WQGH734 M Communications Van FM 453.28750 WQGH734 M Communications Van FM 151.02500 158.98500 KVL96 RM Highway Department / Solid Waste FM
Mar 15, 2008 | Uniden BC72XLT Handheld Scanner
Open Questions:
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
