Got a dell inspiron.530 pc.not comeing up on screen .beeping 4 times.need help.
    Brigadier General:
  • 3,400 Answers
Http://www.pcmag.com/encyclopedia/term/38515/beep-codes
i hope this page explain the beeping-codes.
Posted on Apr 21, 2013
  • 3940 Answers
SOURCE: dell inspiron 530s won't boot up and gives me 4
4 Beeps indicates a RAM memory failure. Disconnect power, press and hold the power button to release all power from the motherboard, then re-seat the Memory.
If error doesn't go away, try modules one at a time to find the bad one
Posted on Dec 27, 2009
gurutim
  • 68 Answers
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Posted on Mar 22, 2009
oblivion2k
  • 150 Answers
SOURCE: computer locking at startup
If the LED is glowing Amber then there is definitely something wrong with the hardware. Open up the system and check to make sure that all cables are plugged into the motherboard securely. If they are, you have faulty hardware somewhere. I would take it into a repair shop and see if they can locate the fault.
Please rate,
Thanks!
Posted on Apr 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell Inspiron 530 mobo dead, beeps 2x, no video
The two beep code means no memory was detected. This might mean bad memory, memory that's loose in its socket, or a system board problem.
Make sure all the memory is firmly seated and latched into the sockets.
If you have only one RAM module installed, try substituting a known good part of the same type to see if the trouble clears up. If the memory still isn't detected you'll need a new motherboard.
If you have more than one RAM module, try them one at a time to see if you can isolate which is causing the trouble. (Testing the motherboard with known good memory is always a good thing to try. I have seen computers where all three RAM sticks were bad at one time, so I wrongly thought the motherboard was at fault. I always keep some good memory around for testing now.)
Good luck, and thanks for using Fixya!
Posted on Mar 27, 2010
  • 2666 Answers
SOURCE: Dell Inspiron 530 desktop won't
See here
Posted on Sep 03, 2010
Computer went sleep now it wont come up beeps 4 times
Most beeping problems are indicative of RAM problems. Try popping open the case and removing the RAM modules and plugging them back in.
Aug 12, 2014 | Dell Inspiron 530 Desktop Computer
My Dell Inspiron 530 won't start. 4 Beeps, Soild blue light.
According to Dell this is a RAM issue. You can find a list of diagnostic Beep Codes here. Also be sure to inspect the capacitors on your motherboard. If you notice any of them leaking or blown then that is your problem.
If you have extra RAM lying around then swap it into your PC and see if you're having the same problem. If not, pull out any unnecessary RAM just to test it. There are four RAM slots on this PC and you should be able to use any one of them. If your PC turns on then you can isolate which chip is giving you problems. Keep in mind RAM is ideally installed in matched pairs.
If you only have one RAM chip in your computer then I'm afraid you will either have to buy another one or borrow one from a friend to test. Shouldn't be too expensive anyway.
Jul 24, 2012 | Dell Inspiron 530 Desktop Computer
When i start my dell inspiron 530 desktop....
according to dell's documentation, 2 short beeps means a memory problem. try the suggested remedy in their site.
don't forget to rate me if I was able to help out. :)
Jan 10, 2012 | Dell Inspiron 530 Desktop Computer
I have a Inspiron 530... The monitor reads "NO
Hello
You may try another graphic card, it is quite possible the card may not compatible with board, also push the RAM stick to place them properly may the RAM gone dislocated.
Hope it helps
Dec 30, 2010 | Dell desktop and monitor- Inspiron 530...
Most of the time my INspiron 530 does not boot up. the screen is blank and the fan runs high. Sometimes it beeps 4 times. What could be the problem?
Sounds like you have hard drive problems !! Check the Bios and see if the hard drive is being recognized or it might tell you that it is faulty by not showing up at all.
Nov 01, 2010 | Dell Inspiron 530 Desktop Computer
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
