Question about Encore Software Kawasaki Jet Ski Watercraft for Windows
Where do I connect water hose to flush engine on 1995 sts 750 Kawasaki jet ski
heimlich
  • 1978 Answers
SOURCE: 1995 kawasaki jet ski guages wont work is there a
There is/are fuses in the electronics box. Most ski's have just one main fuse for the whole machine. I suggest unplugging all the wire connections and plugging them back in, you probably just have a problem with continuity. If the gauges are all bad , you might find a good used set on EBAY. Just remember the gauges are pretty and cool but not really necessary as long as you fill your oil tank before riding and drive with the fuel petcock in the ON position.
Posted on Sep 03, 2010
heimlich
  • 1978 Answers
SOURCE: i have a 1995 kawasaki zxi the bolts on top of
The numbers on the head are the torque pattern/order. Two stroke motors generally use a torque value of 18 to 22 foot pounds on the head bolts/nuts.
heimlich
  • 1978 Answers
SOURCE: How do you adjust kawasaki 750 ss jet ski carb?
Stock needle settings are: LOW 3/4 +/- 1/4 . HIGH 1 1/4 +/- 1/4
Posted on Sep 04, 2010
heimlich
  • 1978 Answers
SOURCE: What oil and how to you check it in a 93 kawsaki
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Posted on Aug 16, 2011
SOURCE: i have a 1999 kawasaki 900 stx jet ski.last week
my kawasaki 900 stx got no spark to plugs what could be wrong thanks
Posted on Sep 26, 2011
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
damaged impellor or housing , grabbing air !
Dec 19, 2013 | WSM 1995-1997 Kawasaki 750 Zxi Cdi...
Kawasaki watercraft
compression check , 100psi or more ! battery and connections good ?
Jul 06, 2013 | WSM 1995-1997 Kawasaki Sxi 750 Cc Jet Ski...
Kawasaki 750 sts jet ski engine hydrolocked now engine will not turn over help!!!
Pull all spark plugs, turn the engine over and purge the water, reinstall and start up.
Apr 08, 2012 | Video Game Consoles & Games
I have a 1995 kawasaki ts jet ski it runs but goes really slow will not hit high end. i just got this jet ski it looks like the carb and lower end of motor is new. i did find some water in carb and cleand...
If the carburetor was properly cleaned including the teeter-totter float needle then you may just have accidentally changed the setting screws. Try setting the the high end and low end adjustment screws the standard settings are: Low speed screw: 3/4 turns out (+ or - 1/4 turn for fine tuning) high speed screw: 1 1/4 turns out (+ or - 1/4 turn for fine tuning) If the previous owner rebuilt the whole machine but could not figure out why the boat would not rev out, the next thing to do is remove the water box and and split the halves. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch27834 If a mouse nest has been built in the exhaust system the extra back pressure could be the problem. If the exhaust coupler has broken rubber tubes, has come apart, or has not been put together correctly that might also be the cause of the problem. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch29444
Aug 08, 2011 | kawasaki Full Suspension Mountain Bike Men
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
1995 kawasaki 750 jet ski overheats when going fast
Check your plug color. You may be having a high speed mixture problem. Is your ski spitting water out the tiny hole on the side? You should try flushing the engine, you could have a motor full of sand if you beach the craft but do not wash the sand out of the back before starting. Also inspect the engine water tubes for cracks. From the hull to the motor and from the hull to the jet pump.
Aug 26, 2010 | kawasaki Full Suspension Mountain Bike Men
Where do you read the mileage on a 1996 Kawasaki 750 sts jet ski?
I hate to tell you this but we go by hrs. the motor has ran for if theres not a hr.meter on the jet-ski you well need to istemate on how many hrs.it has ran.If you think maybe the water impeller needs to be replace,it won't hurt.better to replace then be stuck.
Jun 17, 2010 | kawasaki Full Suspension Mountain Bike Men
Encore Software Kawasaki Jet Ski Watercraft for Windows Logo
52 people viewed this question
Top Encore Software Video Game Consoles & Games Experts
James Wishart
Are you an Encore Software Video Game Console and Game Expert? Answer questions, earn points and help others
