Question about Kitchen Ranges
I have a frigidaire gallery propane stove. I just bought it a couple weeks ago. We converted in from natural gas to propane, the top works great but the ovens gives off a terrible smell whenever we use it. At first I thought it was just because it was new but we have used it a lot and it still smells. The flames come all the way up into the oven and now all of my racks are covered in black soot. Have you ever heard of this? Could my oven be getting too much propane? Could it be defective?
THAT IS VERY COMMON,YOU HAVE TO EITHER CHANGE THE ORFFICE ON THE OVEN AS WELL OR ADJUSTED,TURN IT DOWN CLOCK WISE TO REDUCE THE GAS FLOW,THEN OPEN THE AIR FLOW WINDOW ALL THE WAY,ADJUST 1/2 A TURN AT THE TIME .....AND PRESTO
Posted on Apr 21, 2013
ldaala
  • 65 Answers
SOURCE: Smelling Gas and Soot in Oven
well its pretty normal u will smell gas when its preheating but if u think its not then u can pull the oven out and check the gas line connection is tight if it is then u can also get a spray bottle of soapy water and spray the whole line and if u see alot of bubbles then there is ur leak and for the soot problem u can use the clean cycle which all it does is reach a very high temp and pretty much burns everything like crumbs to a crisp and all u have to do is basically wipe it out with a damp cloth and maybe a mild soap and sponge good luck
Posted on May 18, 2009
milten1
  • 1304 Answers
SOURCE: my kenmore stove was supposedly converted to
its not properly converted
sounds like the forgot to flip your gas vale head pin
Posted on Oct 05, 2009
  • 1891 Answers
SOURCE: frigidair gallery old stove/oven gass, when I put
replace oven ignitor .
Posted on Nov 20, 2009
  • 1531 Answers
SOURCE: I bought gas cook stove
There is a regulator behind the bottom drawer remove the drawer.look in the back you will see a silver box that the oven fuel rail is on just below the rail there is a brass fitting that needs to be turned clockwise till it stops it can be hard to turn some times but turn it till there is no clearance between the nut part of the valve and the silver box then you can start your oven and it should work fine you can also adjust it to get a little more flame if needed.
Posted on Feb 03, 2011
  • 4 Answers
SOURCE: Gas smell after oven is shut off-We just bought a used Tappen gas stove. It was set up for propane but we have natural gas. My husband adjusted all the flames and the burners and oven work fine. Howev
has to be an internal leak in the ovens tube
Posted on Jun 09, 2012
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
I bought a used direct vent vermont castings radiance model 2600 set up for natgas. I have been trying to get it converted to propane, with no luck. All dealers are telling me that the conversion kit is no...
if you know a lot about it you could convert it your self....you need to get rid of the Propane regulator....you need a Natural Gas Valve and you need to change the orifices....should be stamped on the rating plate the size of orifice for natural gas....I wouldn't recommend you do it yourself unless you have a license....or as I said know a lot about it...I wouldn't have a problem doing it in my own house...however you run into Insurance implications should anything happen if it's not an approved kit from the mfg.
Oct 19, 2009 | Heating & Cooling
How do you convert from propane to natural gas
You have to change the orifices in the burners. Normally the orifices are supplied with the stove and are attached under the stove top somewhere.
Oct 03, 2009 | Frigidaire GLGF366 Gas Kitchen Range
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
How to check to see if gas stove has been converted to propane
The only thing you can do is look for a little (usually gold) nozzle connected to the orfice
propane burns blue and natural gas has the yellow tint to it
May 01, 2008 | Ovens
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
117 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
