Question about Sharp Aquos LC60E77UN LCD TV
Long delay when turning on
When I click on my television it take a very long time to come on, what could be wrong?
    New Friend:
    Problem Solver:
  • 9 Answers
Well, it most likely has to warm up, large flatscreen televisions have to be on theoretically for 2 hours before they are accustomed to running.
Another reason could be with the auto-detection of the signal. If it is busy scrolling and looking for a signal from other inputs then it may take a while if your particular input is lower in the list.
It is most likely the second option.
Posted on Jun 26, 2013
The dishwasher is displaying 5H in the time panel is there any way that could happen by pushing the wrong button and is there any way to make it go away
It would help to know the model number to determine the features of your dishwasher. The only guess I can make is that someone pushed the "delay" button and you are now set for a 5 hour delay for starting the dishwasher. Pressing the Delay button a few more times should bring it back to Zero delay.
Feb 28, 2015 | GE Dishwashers
46 inch samsung delay in turning on
Delay in turning on is mostly caused by weak and defective electrolytic capacitors in the power supply board. Most of the times they are easily recognized by their bulged top. Some times one has to hunt for them. If one can do it, it is a simple job. Good luck to you.
Dec 29, 2013 | LG RU-42PX10 42 in. HD-Ready Plasma...
Samsung LCD 1080 flat screen tv model LNT4661FX/XXA clicks before taking 30 seconds to turn on.
Delay in turning on in flat panel TVs is mostly caused by weak and defective electrolytic capacitors in the power supply board. Most of the times they are easily recognized by their bulged top. Some times one has to hunt for them. If one can do it, it is a simple job. Good luck to you.
Dec 29, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
Hi I have a Samsung LE46M86BDX , and its beginning to take longer time beforer showing the picture, normally you can hear a "click" after 2-5 sec. and the picture shows, for a few days ago the "click"...
I had the same problem. http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related We're not alone - its a common problem with Samsung. I watched a few of these and was able to see the bad capacitors, de-soldered and replaced them for under $5.00.
Sep 01, 2010 | Samsung 32 in. LCD Monitor TV
2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Feb 12, 2010 | 2007 Dodge Ram Truck
Projection television fails to completely power up
Have you replaced the lamp since you brought the set, if not or if it has been at least 2 years or more replace the lamp..
Please leave a comment, THANK you..
Oct 24, 2009 | Televison & Video
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
Tv will not turn on
My TV had a simular issue...delayed power-on with repetitive clicking. I found a post at Techreport.com about bad capacitors on the power board. This and other Samsung models seem to have an issue with these components failing. I replaced the capcitors myself last night, and the tv is now working perfectly. Cost me about $15 in parts and an hours time. Hope this helps!
Jul 03, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Breadmaker Won't Start
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
Feb 09, 2008 | Black & Decker B2000 Bread Maker
Delay Start doesn't function
Does the power go off in your house from time to time? Have you tried to do a 2-hr delay during the day so you can watch it? Keep checking every 15 min. or so to see approx. when it shuts off.
Aug 18, 2006 | Frigidaire 24 in. FDB1250RE Built-in...
Sharp Aquos LC60E77UN LCD TV Logo
130 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
