Audio problem Actually, this is about an RCA DVD 8310NC Recorder/VCR. When I try to record either with any DVD or video tape, the recorded program has very loud static sounds. The picture appears to be okay. I've had this recorder for about 18 months & never had any problems until now. Everything seems to be hooked up right. I've cleaned both DVD & VCR lens, but it doesn't make any difference. Can anyone tell me something else to try?
SOURCE:
SOURCE: RCA recorder just purchased
I ckd the internet and found that this recorder had a lot of problems and solved the problem by returning it to the store.
Posted on Nov 18, 2008
  • 55 Answers
SOURCE: go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Posted on Jan 16, 2009
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
  • 4 Answers
SOURCE: dvd vcr will not even recognise a tape in the recorder
put a piece of scotch tape over the little square on the tape platic case bottom left......your recorder thinks it is a protected tape
Posted on Mar 05, 2009
SOURCE: How to Record TV Programs w/o Cable Box/Satellite Receiver?
Ok, I had this issue. And this is what you need. Even if you have a new HDTV, you need a converter box. The new TVs are not made to send out the signal just take it in. Best price I have seen on converter boxes was H.E.B
1. Antenna to converter box
2. Converter box to VCR
3. VCR to T.V
You will have to leave the converter box on when you are recording or leave it on when you leave the house. Also it has to be on the channel you are recording and the TV needs to be on channel 3 or 4. When you program your VCR it needs to be for the time and stuff. But put it to record channel 3 or 4. Which ever you pick for it to record off of. It really is easy. But I do hate that the people that had this great idea made it to where we can only record from one channel. I am going to try to send a diagram that I drew. Not the best artist, but you can tell what I mean. I can not seem to get it to attach the attachment. But you should not have a problem. Good Luck :-)
Posted on Apr 18, 2009
Can't find the correct way to hook up my vcr to my dvd recorder to record vhs to dvd disc. could someone please give me some instuctions on hookup please. thanks
connect yellow, red, and white RCA jacks (video, audio rt and lt) to the "out" on the VCR. If your VCR isn't stereo it will only have one audio plug.
Connect the other end of the jacks 9yellow, red, and white) to the "in" jacks probably marked Aux in, on the DVD recorder.
Now follow the instructions on the DVD recorder to set to Aux in (some have two aux front and back). Should have a button for it on the remote.
With the dvd, tv , and vcr on, you should see the VCR on the screen. Start the tape and press record on the dvd, you are set.
Mar 02, 2010 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Need to transfer order VCR-C tapes to DVD How
You will need to borrow or buy a DVD-Recorder, either way it's best to follow the manuals instructions on how to connect your camcorder (external device) to the DVD Recorder for Recording to DVD. Most camcorders come with a set of AV (audio/video) Cables for this purpose. On your camcorder you will find a little rubber door that houses the terminals to connect your cables to. Depending on how old your camcorder is you will find a Yellow (video) and a White (audio) and on the newer ones that have stereo capabilities...you will have a Red (audio), all these connections are video and audio Out-Inputs and should be connected to the Video and Audio "In" terminals on the back of the DVD Recorder. Now make sure your battery is fully charged (It's best here to use an AC Adapter for your power supply instead of your battery, which also usually comes with your camcorder if bought new.) and that your VCR-C tape is loaded and completely re-wound. Now if you want to watch this on your TV while you are recording to DVD...you'll need another set of AV Cables that come with a new DVD-Recorder, and hook these cables on the Out-terminals on the back of the DVD- Recorder and the other end of the cables to your TV's Video/Audio-IN terminals on the back of the set. Finally...Set your camcorder switch for Playback, turn on the DVD Recorder, And turn on your TV. Now you can go ahead and record all your VCR-C tapes to DVD! Any other questions? Contact me directly at over4dy@yahoo.com
Jul 29, 2009 | Video Cameras
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Want to transfer vhs tape to dvd
not sure why you would need an rca to s-video adapter, almost every dvd recorder and vhs has rca input and ouput.
anyway here is the basics to record from vhs to dvd you would connect the OUTPUT video (yellow) and right and left audio OUTPUT (red and white) to the dvd recorders INPUTS.
Dec 29, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Computers & Internet Logo
Alun Cox
k24674
