Question about Garden
'01 Toro Zmaster...cuts off after running 20-30 minutes. will start right back up but will cut off again. After letting cool off I can mow again. changed spark plugs, cleaned air filter
Just changed oil & filter.
  • 7,482 Answers
Hi
When your leaf blower quits after it gets hot, you either have a problem with gas flow being restricted into the engine or with the spark. This is a common occurrence on older-model leafblowers. By replacing your spark plugs and keeping your gas lines clear you can reduce the chances of this problem recurring.
Possible Vapor Lock:
Vapor lock happens when excessive heat and vapors build up in the gas tank and aren't vented properly. Check for this problem the next time your saw dies when it's hot. Unscrew the gas cap, vent the gasses and try to restart your blower. If it starts you have vapor lock, and will need to carefully inspect the fuel tank's vent hole to see if it is plugged or damaged. Clean this hole with a brush and rag.
Possible Ignition Problems:
A common problem is an old or dirty spark plug. When the plug gets covered in black carbon the spark will have difficulty firing, especially when hot. You may also have a problem in the ignition module or the coil in the module. Again, run the blower until it quits and then squirt a little starter fluid into the open choke valve, underneath the air filter. If it starts up you likely have a fuel system problem, but if it doesn't start, your ignition module or coil is likely almost finished.
Fuel Supply:
At certain times when the engine gets hot, the flow of fuel to the carburetor can get restricted. This can occur with a dirty fuel filter on the end of your main hose. The hose itself, when hot, can also lose its proper seal to the carburetor, restricting the flow. Replace your fuel filter and hoses on a regular basis, usually once a season. Try adjusting your carburetor's screws to see if you can richen the fuel mixture in the carburetor.
Other Problems:
A dirty or worn-out carburetor can also cause similar problems when hot. You should get your carburetor cleaned and serviced. Try installing a carb kit to older carburetors to help with the flow of fuel. A fuel pump inside the carburetor can also start failing and any warping in the diaphragms will also cause similar problems. You can check for a dirty carburetor by squirting a shot of carb cleaner into the open choke hole just after starting the engine. If you see a lot of thick, dark smoke pouring out the muffler, your carburetor is dirty.
Please take time to rate me
Bud
Posted on Apr 25, 2013
dontbother10
  • 2220 Answers
SOURCE: Toro self-propelled, 6.5 electric starter, three
Did you rate this? We are having a problem with self rating by our experts. If you did not rate this or do not believe it warrants a rating of very helpful please rate it as NOT HELPFUL. Experts cannot override your rating and seems to be the only way to stop this practice.
Posted on Dec 06, 2009
  • 97 Answers
SOURCE: leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Posted on Mar 19, 2009
SOURCE: My toro self propelled only runs for a few
Have you tried replacing the gas cap? I had the same problem with my mower and did everything you have done, changed gas cap no problem since
Posted on Jul 25, 2009
Grumman_1
  • 12 Answers
SOURCE: Toro 6.5 Tecumseh Recycler won't stay running
I have the same mower and problem. Found out the issue was the carburetor. Pull the Carb and do a quick cleaning. Order the replacement kit prior to working on. My bowl o-ring was shot and I couldn't get a seal after cleaning it out.
Posted on Jan 18, 2010
barterjoe
  • 338 Answers
SOURCE: We have Toro Lwa 100 Lawn Mower Model #26623.
This 1991-92 model is equipped with a blade brake clutch. When the blade slows down this means the belt is slipping. This slipping can be caused from a few different things.
Try adjusting the blade cable on the upper handle. this unit has an adjustable section. make sure the cable is not so tight that you snap it.
2 --A sticky pivot point under the belt cover
The belt cover in the back builds up with dirt and debris. Make sude it is clean under the cover and all of the pivots move freely. ( do this with the engine off)
3 --A sticky belt tensioner under the deck cover
The underside of this machine has a metal cover to protect the belts. Remove it and check that the blade belt idler arm is not frozen in place. this will cause the belt not to enguage all the way.
4 --A worn belt or belt pulley
The large flywheel and pulley can wear. Check this if the belt looks good.
This is all there is to the machine BBC system.
I hope this helps.
Get parts and more diagrams at a Master Toro Dealer like www.arcolawn.com
Posted on Mar 02, 2011
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
My toro ride on mower cuts out after 45 minutes or so have to let it cool down for awhile before i can start it
Try this:
As soon as the mower begins to shut off, stop, keep it running, lift the hood and loosen the gas cap. If it begins to run better, clear the vent hole on the cap. If not, you have wasted very little time.
Gary
Feb 27, 2011 | Toro Garden
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Hope this isn't a double post. Yardman push lawn mower rear bag starts right up and then mows about 6 rows before stopping. I start it again and it mows about a row and stalls. I let it sit for about an...
it sounds like you may have a vapor lock on your fuel tank   there should be a diaphragm on the inside of the fuel cap  that lets air in but not out   it may have an air hole clogged  take the cap apart if you can and clean it real good and put it back together   if that is not it  then the float in your tank may be stuck   or a fuel line filter may be clogged
Nov 07, 2009 | Toro Lawn Mower With Toro Power Tools
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
My lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 12, 2009 | Garden
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
