Question about Home
I have a new Jacuzzi air tub and was ready to install. When I plug in the motor, there is a humming noise. What is this?
  • 717 Answers
When you turn on the motor and if it just hums when you turn it on then the motor sounds bad.
Rod
US Parts Center
888-521-6183
Posted on Apr 25, 2013
SOURCE: JACUZZI HOT TUB J365
MOTOR TO HOT TUB KICKS OFF ON HIGH SPEED AND GETS VERY HOT AFTER RUNNING ABOUT 20MINUTES AND STARTS BACK UP IN LESS THAN A MINUTE,BUT CONTINUES TO KICK OUT ,IVE REPLACED THE MOTOR AND STILL SAME PROBLEM..
Posted on Oct 24, 2008
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
  • 41 Answers
SOURCE: We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Posted on Mar 03, 2010
  • 33 Answers
SOURCE: my jacuzzi tub will not
mine did the same thing. the tub is plugged into a ground fault interupter (gfi) plug. hit the reset button. if this doesn't work, check the circuit the gfi is on, sometimes they are on the same circuit as the plugs at the sink. check them for reset also. if this fails, on the motor of the tub, there should be a reset button. try to reset it. OH first make sure the breaker has not been tripped.
Posted on Jan 04, 2011
  • 91 Answers
SOURCE: My jacuzzi bath tub makes
Pump was humming, suspect air lock, pump could of burnt out, check power to pump and if it blows fuses then you will need a new pump and don't forget to bleed the pump
Posted on Jul 16, 2011
I have a Hyflo jacuzzi bathtub pump. I just tried to turn it on and it hums and acts like it wants to work but it's not pumping. I had this problem with a hot tub pump and all I had to do was blee
If you motor is just humming then it is not starting and is no good.
HyFlo pumps were made by HydraBaths in the 1990's. They are no longer made. We have replacements for them.
Rod
US Parts Center
Feb 01, 2013 | Home
My Jacuzzi Tub won't start
Try compressed air through the system,careful not to use too much pressure. Also you may use another water pump to push water through system and free up the motor. The easiest thing may be to get a new motor though.
Dec 10, 2012 | Home
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
My jacuzzi bath tub makes a humming noise when I turn it on, but it will not operate. I tried again later, and still nothing, and not even the hum now.
Jul 16, 2011 | Jacuzzi Home
I have a Jacuzzi tub and the vacuum switch will not turn the tub off. I had to turn the breaker off.
if when you push the air button it will not turn off the pump, it may be the button that is bad on the top of the tub or the air switch located in the motor.
take the pump out and plug it into an outlet. get a straw and blow into the air switch with the pump plugged in still. if it comes on then the button on the top of the tub is bad. if it doesn't come on then the air switch is bad.
Feb 16, 2011 | Jacuzzi Home
My american standard jacuzzi tub doesnt work. It's plugged in, but the push button doesn't engage anything. It worked before I removed it to install ceramic tile around and under it.
check the air tubing coming off the back of the motor. that tubing should connect from the air switch on the motor to the bottom of the air button on the top of your tub.
if it is not connected then it will never turn on.
Feb 03, 2011 | American Standard Home
My jacuzzi tub will not come on . fist it was making a humming sound , i turned it off checked the reset plug tried to turn it on and not a sound
Jan 04, 2011 | Jacuzzi 4481-959 Nova 5 Soaking Bath 5'-...
American standard jacuzzi tub will not work. motor hums but jets do not come on
is this a new install? if so you may need to adjust the air intake. Or if you have kids they may have messed with the settings. If the air is closed all the way off....no bubbles.
Oct 18, 2009 | American Standard Antiquity 2038.016.020...
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Bath tub spa will not shut off
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Feb 21, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
80 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
