Question about Earthwise 1750 Psi Pressure Washer
How to use a pressure washer
Im trying to figure out how to insert my house onto the pressure washer
Where does the detergent bottle go
It goes onto the wand itself. With the Pressure Washer off: If you have the wand unattached from the hose it works easier. Then separate the WAND into two pieces at the big joint in the center. Insert the bottle into the joint on the opposite end of the section that will be attached to the hose, (once you have the wand in two pieces you will see the same types of connections that are on the bottle.) then attach the other end of the wand to the bottle. Now reattach the wand to the hose.
Dec 03, 2014 | Campbell Hausfeld PW1750 Electric Pressure...
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
Stihl fs55rc rotor spring
Determine which direction it needs to go to pull the cord out of the hole and COMPRESS the spring. put the tab on the tail end into the housing, and put the white spool in the inner end of the spring. rotate the spool while keeping your finger on the spring to hold it onto the spool. Once it's sufficiently wound enough to fit back into the housing, insert it and reinstall the washer and clip.
Jun 04, 2012 | Stihl Garden
How to replace stop light?
Tail Lights
The procedure for removing and installing turn signal light bulbs is the same as that for brake light and taillight bulbs. Only the procedure for brake light and taillight bulbs is described here.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the battery.
  3. Switch off all electrical connectors.
  4. Turn off ignition.
  5. Remove the rear light, as follows:
  6. Remove the rear striker mount cover.
  7. Reach behind the respective quarter panel trim and unscrew the knurled nut. Make sure the washer and spacer do not fall down.
Taillight housing
  • Remove the rear light and disconnect the electrical connector.
  • Turn the bulb holder in the direction shown and remove from the housing
    1. Remove the bulb from holder.
    To install:
    1. Install the bulb in the reverse order of removal. When installing, make sure bulb holder engages in housing by turning in opposite direction.
    2. Install the rear light, as follows:
    3. Connect the electrical connector.
    4. Insert the rear light housing into the body opening.
    5. Insert the retaining bolt into the body opening.
    6. Insert the rear light into the cutout.
    Insert the rear light into the cutout in the direction of arrow
  • Slide the spacer and washer onto the retaining bolt, attach the knurled nut and tighten by hand.
  • Turn the bulb holder in the direction shown and remove from housing.
  • // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 31; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
    Dec 25, 2010 | 2000 Volkswagen Beetle
    Im trying to locate the Evaporative emission control system pressure sensor low input on a 2002 buick century?
    It is built onto the fuel pump. You can access the fuel pump in the trunk under the carpet. Remove the bolts from the rectangular cover and it is the black sensor pushed into the fuel pump housing.
    May 18, 2010 | 2002 Buick Century
    How do you change the nozzle? We borrowed this unit and can't figure it out.
    On most pressure washers the nozzle is inserted into a quick connect. Simply grasp the outside of the housing holding the nozzle and pull back. The nozzle will come out. While holding the spring loaded connector back insert a new nozzle and release. In some case there is a slot and the quick connect must be orientated so the slot lines up with a pin. If the end looks like this, then it is a quick connect. Grasp it and pull back. ecae845.png
    Apr 24, 2010 | Karcher 2500 PSI Pressure Washer
    Pressure washer - can't figure out soap
    Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
    Apr 09, 2009 | House Brand Garden
    Earthwise 1750 Psi Pressure Washer Logo
    48 people viewed this question
    Top Earthwise Garden Experts
    Steve Sweetleaf
    Steve Sweetleaf
     Larry
    Larry
    Call Bill
    Call Bill
    Are you an Earthwise Garden Expert? Answer questions, earn points and help others
