Question about Crosley CR248 Shelf System
Cd drawer won't open - Crosley CR248 Shelf System
  • Crosley Master
  • 5,151 Answers
Chances are a small belt has come off. Very easy to replace if you can get inside it!
Posted on Apr 24, 2013
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
Tascam CDR-W5000 CD Recorder won't open the tray (drawer). Please help!
This could be a bad belt or a defective end sense switch. The parts are no longer available I am told for this unit by New Jersey Factory Service where the could be fixed. This is one of the older models.
Dec 06, 2012 | Audio Players & Recorders
Cd player won't open with the push of the button
Mechanical or electronical drawer?
Is the button stuck?
Oct 25, 2012 | Acer Aspire T135 PC Desktop
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
HP Z1 WORKSTATION WON'T EJECT CD
Make sure the computer is turned on then Take a Paper Clip (Gem Clip) and straighten it out then kneel in front of the desktop facing the cd drawer. Look closely at the drawer and you will see tiny hole where you will insert the paper clip (Gem Clip) and at the same time Press the Button on the cd drawer while applying pressure by pushing the paper clip (Gem Clip). The drawer will pop open. Don't worry about breaking something, that's why that tiny hole is there.
Jun 02, 2012 | Computers & Internet
I have a Phillips model 601/25 CD player and the CD drawer won't open - it makes a whirring noise but refuses to open.\r\n J A Adamson <jadamson35@gmail.com>
The rubber band has stretched with age. Easy fix, take cover off (several screws around the case) and band is easily accessed. Even a cheap elastic band will work as a replacement for now, it only opens the drawer mechanism, no effect on sound quality.
Aug 20, 2011 | Philips Audio Players & Recorders
Crosley CR248 Shelf System Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
