Sony Xperia sk17i running slow no incoming message alerts
SOURCE: w880i not ringing or message alert
Ok, Might seem like a daft question but is it on silent?
I'm guessing you chekced this already but it's easy to miss.
The first thing to check is whether it will make any sound at all - this is a good guide as to whether the speaker is broke or just settings are wrong. Being a Walkman phone you might have some tunes on it so see if they play. Do this through the walkman/media player feature as apposed to the ringtone area.
If they play then you know it's still working and some settings need changing. If not your speaker might be broken.
If the speaker works then you need to check the ringer volume. this can be done from MENU/SETTINGS/SOUNDS&ALERTS/RING VOLUME - this then needs to be set using left and right to go up and down.
After this is set test call the handset to see. If still no luck change the ringtone to another tone - something built into the handset preferably - might be a faulty tune. If still no luck check the the number calling the handset has not got any sound preferences - i.e. no tune when call received. If still no luck it might be broke...
hope this helps some what...
1. Switch ON your Sony Ericsson Xperia X10 mini pro with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X10 mini pro will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X10 mini pro phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X10 mini pro is locked to.
