Question about Samsung Q430 Laptop
Keyboard replace ribbon connections
  • Samsung Master
  • 5,660 Answers
Forgive me, not advertising for these guys,
http://www.laptopkeyboard.com/Guides.php/Samsung/Q%20Series/Q430/KBSG5
(They say, "A picture is worth a thousand words")
As new as the Samsung Q430 series of Notebook PC's is, there should be only two different types of ZIF connectors on the motherboard, used for the Keyboard Cable. But may be three;
A ZIF connector is a Zero Insertion Force connector. The motherboard connector on a laptop, that the Keyboard Cable goes into, is a style of ZIF connector.
Usually composed of two parts; The bottom part is larger in size, and is Stationary to the motherboard. It is called the BODY.
The upper part is smaller in size, and is Movable. It is the Locking Bar. Uses the wedge principle when in the closed/locked position, to wedge the Keyboard Cable into the Body.
1) The newest style has no Locking Bar to release. The Keyboard Cable is gently, yet firmly, pulled on; and removed from the motherboard connector. To reinstall just line it up as it was originally, then push in.
2) I refer to this as the Flip-Up style;
Closed/Locked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
Open/Unlocked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
3) And an older style. I refer to this style as the Slide style;
Closed/Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-10.jpg
Open/Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-11.jpg
All you can see are two 'Tab's of the Locking Bar, on each side of the Keyboard Cable.
These Tabs are EASED up with your thumbnails. Ease up on one side a little, then the other side; then both sides.
Moves approximately 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O <-
IF,....the Locking Bar is broken, or IF,...the Body is broken; you are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed.
Note that other motherboard connectors, may use a ZIF connector of one of the types stated above, also.
Touchpad Cable, etc.
When replacing a Keyboard, line the flat bar terminals strips on the Keyboard Cable, back up to the contact pins in the motherboard connector.
The Keyboard Cable MUST go back in the same position, as it was originally. Therefore look at the old Keyboard, and it's cable; to orient the new Keyboard Cable correctly.
For additional questions please post in a Comment.
Regards, joecoolvette
Posted on Apr 21, 2013
Replace ribbon cable in folding keyboard??
Go to www.ebay.com Type: make and model of laptop, refine search to keyboard and ribbon cable. Since I don't know the brand of laptop or model see what turns up.
May 04, 2012 | Computers & Internet
Am using toshiba satellite L505-10w my keyboard is not working so how can i get solution
So your Toshiba laptop keyboard isn't working like it should? Whether your keyboard problem resulted from liquid spill, a hard bump, or you simply wore it out, you don't have to worry about investing in a new laptop, you can fix your keyboard problems with a simple swap. The good news is that fixing a Toshiba keyboard does not take much technical skill. In fact, Toshiba keyboards are among the easiest laptops to repair.
1.Remove the bezel just above the keyboard. You will notice a tin strip of plastic located just above the keyboard. This strip is called the keyboard bezel and you remove it by gently prying the edge up with your small standard screwdriver. Work your way across the bezel lifting it as you go. The bezel is a snap in unit so be sure to be gentle, as you work your way across.
2.Remove the keyboard screws. With the bezel removed, you will find three or four screws at the top of the keyboard. Using your small Philips head screw driver, remove these screws and place them in a safe spot where you will not lose them.
3.Remove the keyboard. With the screws removed, gently lift the keyboard from top to bottom. You will notice a ribbon of wires connected from the keyboard to the laptop. Lean the keyboard forward so that you can access the ribbon wire connection.
4.Remove the ribbon wire. Take your standard screw driver and gently push up the bracket locks on both sides of the ribbon wire socket. These bracket locks slide up slightly as you push to release the wire.
5.Plug in the replacement keyboard. Just as you removed the old keyboard, you will now push the ribbon wire from you replacement into the ribbon socket. With the small screw driver, push the brackets back into place to secure the ribbon.
6.Screw the replacement keyboard back into place. Using one screw, attach the keyboard. With the keyboard held into place by the single screw, start the computer and test the replacement keyboard. Once tested, replace the remaining screws.
7.Insert the bezel above the keyboard. With the keyboard now secured by all of the screws, place the bezel back over its opening and snap it back into place. Start at one end and work your way across.
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Toshiba Satellite A105 Notebook
My dell computer's letters a,s,d,f,j,k,and l don't work
hi,
best solution is to replace your keyboard.
Feb 04, 2011 | Dell Computers & Internet
My laptop keys are messed up
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one
Sep 29, 2010 | Acer NSK8458AN Keyboard
Some of my laptop keyboard is not working
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 28, 2010 | Computers & Internet
Keyboard not working
Sep 24, 2010 | Computers & Internet
I have replaced my Toshiba 205 laptop's keyboard a few months ago and all was fine. Now some keys don't work while others work if you push for a few seconds. I reconnected the ribbon last night and...
Sep 20, 2010 | Toshiba Satellite A205-S4607 Notebook PC
Sep 20, 2010 | Computers & Internet
Some of keys on keyboard not works
Sep 19, 2010 | Computers & Internet
Keyboard not responding
Sep 05, 2010 | Computers & Internet
Samsung Q430 Laptop Logo
101 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
