Question about Garden
Where is the drain plug on a john deere sabre
  • 133 Answers
SOURCE: I have a john deere sabre 15.5/42 and cant figure
Remember to always put the V side of belt (inside of belt) into the pulleys and put the flat side of belt (outside of belt) up against the idler pulley (the one that moves to make belt tight to engage blades) Make sure you have the right belt and follow those guidelines and the belt should go right on. If you happen to have alot of slack then you have to figure out a different routing around the idler. Make sure the blades are NOT engaged. When on properly the belt will be snug.
Let me know if this helps.
roundo4
Posted on Aug 29, 2009
bargainbin2
  • 123 Answers
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Posted on Sep 01, 2009
  • 10 Answers
SOURCE: John Deere X324 drains the battery
might have a short in your seloniod switch if you unhook pos from it and there is spark hooking up its probably the short
Posted on Sep 08, 2009
mowerman1857
  • 389 Answers
SOURCE: drive belt on a sabre by john deere 42 inch,
Since you didn't ask any question or say what you wanted to know about the belt, you can go to johndeereparts.com , click on parts catalog, enter your model number, click on sectional index and the click on Belt drive and Idlers for which ever transaxle you have. It will show you a very clear picture of the belt and its routing, also gives you the part numbers for each
Posted on Oct 31, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
What kind of oil is used in a sabre hydrostatic transmission
John Deere transmission fluid recommendations
For Sabre? and Scotts? garden tractors and commercial mowers
This bulletin serves to clarify the transmission fluid service requirements for several models of lawn and garden product and commercial mowing equipment that were recently introduced. The operator's manuals for these products call for 20W50 synthetic oil, which is not carried in the John Deere parts system.
The following chart has been developed from the factory and engineering as approved replacements for 20W50 in each application, and should supplement the information previously published. Transmission fluid recommendations Machine Model Recommended oil for service requirements Sabre
2048HV
2148HV
2254HV
2354HV
2554HV
Plus-50®, 0W-40
or -John Deere Hy-Gard®
(bothoils are for top-off only) Sabre All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Scotts S2554 Plus-50®, 0W-40 Synthetic
- or -John Deere Hy-Gard®
(both oils are for top-off only) Scotts All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Mid-Ztrak
Mini-Z M653 through M665
737/757
717/727 Plus-50® II, 15W-40
Plus-50®, 0W-40 Synthetic Front-Ztrak F620
F680/F687 Plus-4?, 10W40
- or -
Plus-50® II, 15W-40 QuikTraks 647/657/667 Plus-50®, 0W-40 Synthetic Last modified: 23Jan10.
Apr 03, 2017 | Garden
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
John deer sabre acts like it starving for gas already check fuel filter
is the vent in the gas cap plugged?if it runs better with the choke on part of the way a jet in the carb might be plugged
May 13, 2012 | John Deere Garden
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
Where do i check the trans fluid on a 15.5 hp John Deere Sabre ? Can not see any drains or plugs. It is called a soft touch hydro. Thanks for your help!
Hi, the unit is a sealed type, you cannot change or check the fluid level. Hope this helps, regards Phil.
Jul 18, 2011 | John Deere Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
