Question about Brookstone U-control Silver Bullet Rc Helicopter Easy To Fly Indoors
I bought a new Silver Bullet Helicopter and tried flying it. I had put new sets of batteries in the controller and charged the helicopter. Both red and green lights came ON in the controller. I disconnected the helicopter when the green light went OFF (after 10 minutes)). When I switched ON the helicopter switch, the blue light flicks once and goes OFF. There is no response from the controller in any of the channels. What to do now ?? I tired with another set of batteries but no joy ???
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Helicopter is not getting charged
1) test the contacts and clean it very well +adjust it
2) if after cleaning the problem remain, the power supply inside is faulty. some capacitor, diode, or resistence is faulty. Repair
God bless you
Jan 25, 2013 | Brookstone U-control Silver Bullet Rc...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
4) Power on remote.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
hope this helps,
r
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
I bought on of those falcon-x helicopters for my son and just wanted to know how to charge the battery as efficiently as possible. The helicopter needs to be off correct? And how long should it charge for...
The instructions say the helicopter is ready to fly when the led shows red. I found some info online that says to charge the helo for 35 minutes. I've been letting it go 45 mnutes, and have been getting abou6 6 minute flight times. Unfortunately, my helo will no longer fly forward or backward. Does anyone know how to adjust the control for the tail rotor?
Dec 25, 2010 | Toys
Purchased Helicopter MINI AIR WOLF Model UJ417. from RiverCenter Mall vendor in San Antonio, Texas 3 days ago, while on vacation...live in kansas.Hope i didn't get scammed. Vendor never said it would only...
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
Sep 01, 2010 | Toys
My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
Aug 06, 2009 | Shuttle 9094 Emax Remote Control...
Brookstone U-control Silver Bullet Rc Helicopter Easy To Fly Indoors Logo
Top Brookstone Televison & Video Experts
danoyachtcap
danoyachtcap
Tom Chichester
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
