Question about Superstar SS-3900EGHPA CB Radio
Superstar 3900 el diodo d77 esta en corto no sirve pero no lo encuentro en ningun lada la matricula es ma27t-a cual es su remplazo
  • 219 Answers
SOURCE: what chanel are what
D is your basic 40 channel, this is what most truckers talk on, then C is low, b is double low and a triple low then e is high and f is double high, this radio also has upper and lower side band, most ham operators use these channels. Hope its been convered to talk on CB band.
Posted on Nov 22, 2009
anymhz
  • 500 Answers
SOURCE: convert superstar 3900 to uk frequencies
all is done on the PLL encoding...
Posted on Dec 04, 2009
Mister 44
  • 35 Answers
SOURCE: whats the wiring diagram to connect a sadelta
1) Shield 2) White 3) Brown 4) Green
1) Shield/ Ground
2) Audio
3) Transmit
4) Receive
Posted on Apr 03, 2010
  • 219 Answers
SOURCE: a need help on my superstar 3900 the signal meter
The FM has no forward modulation. You're radio will key up but you can't transmit on it. All cb radio are like that after conversion.
Posted on Jun 02, 2010
anymhz
  • 500 Answers
SOURCE: superstar 3900 ghp gold face
email me i can send you one.
Posted on Feb 26, 2011
Superstar 3900 el led rx/tx cambia a naranja en ves de rojo
There can be several things for that. 1 a bad microphone.2. bad switching diode. or 3 bad rx/tx transistor.. if its staying orange. the #2 is probably the issues.
can you provide more detail, as will it RX.. at all.? will it work in PA mode if theres one? etc
Apr 21, 2013 | Superstar 3900
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Hola mi proplema es cuando ase mucho frio mi veiculo no levanta el compresor si trabaja pero no sube despues lo apago por 10 min y levanta pero despues si la manejo en el trascurso del camino se va bajando...
cambie los levelers o los solenoids si eso no arregla su problema remplase su air suspension con un conversion kit para poner amortiguadores de resorte yo me ahorraria todo ese dolor de cabeza y mejor cambiaria todo a resortes en ves de gastar tanto dinero en sensores y bolsas defectuosas yo cambie mi suspension completa y ya no eh tenido ningun problema busquelos en strutmastercom cuesta al rededor de 800 dolares pero va a gastar mas tratando de remplasar todo lo que esta mal con su suspension espero y esto sea de ayuda para uds
Feb 10, 2011 | 2003 Lincoln Navigator
Me gustaria tener el codigo de mi tv KLH digital no lo encuentro los codigos mi tv y el dvd son juntos los dos y no se como programarlo muchas gracias
Esta Television nesista su propio remote y esta es un problema si usted no la tiene pero si puedo compra una y asi es la unica solucion por esta problema usted cuento la sitio www.remotes.com si puede ayudar en muchos aspectos. Si puede comprar un remote que lo functiona por esta tele es que esta fabrica KLH es moy rado y no tiene la supporte usted esta buscando esto no es problema mia es un problema de frabricante porgue ellos nada mas vende y cerra sus puetos a cliente. Espero que esta informacion ayuda usted pardon mi forma de escribe yo no sabe mucho espano por favor dajar sus votos y propio commentarios positivos Gracias por su visita a fixya.com, Saludos
Nov 18, 2009 | KLH 13" TV
Monitor XVM-R70, NO SE ENCIENDE NI SE PONE EN MARCHA.
Tengo el mismo problema, lo pudiste solucionar.?, gracias
Mar 15, 2009 | Sony XVM-R70 7 in. Car Monitor
ICOM- ICV-100 no transmite y no encuentro el manual de servicio
For a service manual, try Googling (Icom)(ICV-100)(manual) without parens.
Jul 11, 2017 | Audio Players & Recorders
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Noggin
Cual es el numero de chassis?
Me parece que la r414 esta conectada al yugo y su valor es de 0.18 ohmios y 2 watt y el dz402 es un zener de 5.6 voltios.
Si la resistencia se esta quemando es posible que hay un corto circuito en el yugo.
Jan 31, 2008 | Televison & Video
Superstar SS-3900EGHPA CB Radio Logo
98 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
