My laptop Toshiba L300 starts only on safe mode
Suddenly it happened..i had uniblue installed before so i uninstalled it went to the boot and made everything back into default, didnt work.. i even reboot it to tha last good session to no avail..i tried the recovery disk also didnt work and it s telling me that everything is working properly all device..onlu one dll file was missing . and now it is not reading my flash drive
    Problem Solver:
  • 5 Answers
Hi you need to to up grade your microsoft passport net.
Posted on Mar 12, 2009
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that...
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Mar 22, 2011 | Toshiba Satellite Pro L300 Notebook
The laptop is stuck in a cycle and won't start keeps saying configuring updates stage 3 of 3 .0% complete it thenthinks about it then screen goes dark and tries to start again. I have tried to reboot and...
Re boot in safe mode and run 'restore point' from the search box. Select a date/time just before the problem update happened. That will reset your date/time to before the update.
Feb 25, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop is not startting i have a black screen that shows A DISK ERROR OCCURRED PRESS CTRL+ALT+DEL.. HOW CAN I FIX IT? i already try re -started i does not work.
You will have to start in safe mode so follow instrucitons below
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
B52Computers
Jan 10, 2011 | Toshiba Satellite Pro L300 Notebook
MY TOSHIBA SATELLITE PRO LAPTOP WONT GO PAST THE WINDOWS XP LOGO SCREEN AND HAS BEEN FROZEN LIKE THAT FOR HOURS BUT THE LOADING BAR IS STILL MOVING
Hi Good day!!! Try to boot in safe mode, to boot from safe mode, do this: while booting just keep pressing f8 button until advanced boot menu appear after that choose safemode. after that your OS will boot in safemode. if not booting there should be a files missing in your OS you will need to repair it using a CD of you OS. reply to me to help you more
Thank you for using FixYA
Please accept if my solution helps you
Nov 24, 2010 | Toshiba Satellite Pro L300 Notebook
Black screen of death
Try to Run in Safe Mode....
to run in safe mode.......switch on and press F8 cont. until You received the option menu. select the safe mode there.
if not try to start with last known good conf. with same proc.
if it is not work then u have to install ur OS
Jun 28, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satelite Pro L300 won't boot up properly.
firsly start your computer in safe mode then do syatem restore .if problem will not solve then mail me at vicky.akon11@gmail.com
Jun 26, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite l300-1aq laptop is freezing within minutes of start up? I am running Windows Vista. How can I root cause the issue?
When you power up, turn the notebook so you can see if the cooling fan is running.
It sounds like the self protect shut down from over heating.
Feb 01, 2010 | Toshiba Satellite Pro L300 Notebook
I GET A BLUESCREEN AND CURSOR WHEN MY LAPTOP BOOTS
Press F7 while windows statrs and boot the system wih safe mode check whether you are getting blue screen.if you are not getting blue screen, Then the problem was due to improper driver installed for any device. Uninstall the same in safe mode.
Dec 03, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Sep 07, 2009 | Toshiba Satellite Pro L300 Notebook
I bought a Toshiba satellite L300 laptop 5 weeks back. It worked well for 3 weeks. Suddenly it developed a problem. It just started hanging. It would not give any response to cntrl+Alt+del. My only...
If you had had virus problems or if this started to happen after a software installation, you better try restoring your PC to an older state. Go to Start->Accessories->System Restore. Select a date before the problem started. Restore your PC. If the problem still remains, comment back. Also if you have ZoneAlarm, try uninstalling it. That might be the problem in some cases
Jul 30, 2009 | Toshiba Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
