Question about Microsoft Xbox 360 Universal Media Remote
Lost the program codes for the remote
The program codes from a itec g8621 universal remote and the tv is a dynnex and the cable box is a scientific atlanta.. i lost the paper
  • giovanni1703 May 06, 2009
    I hace the same problem!! someone hace the code list for the TV setup?? of the intec xbox 360 universal remote
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
    Hi Jerry, This is from the link below.........
    The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
    Time Warner Cable CLIKR 5 Universal Remote Control
    May 01, 2016 | Magnavox Televison & Video
    I have a Trutech PLV1615T TV and a RCA RCR311 Universal Remote that I lost the info for. How can I get them to talk to each other....Thanks, Tom
    RCA Universal Remote Control Programming Codes Programming Your Universal Remote.The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: y TV-000 y VCR-000 y Cable Box-000 y AUX is programmed with VCR code 037For brands that require programming, there are two ways to program: Using Code Lists or CodeSearch. Use Code Search if the code lists are not available or if the codes from the lists do notoperate a device.Programming a Device using Code Search:1. Manually turn ON your device (TV, VCR, Cable Box)2. Press and "HOLD" CODE SEARCH3. Press and release the device button you want to set up (TV, VCR, Cable Box) However,if you are using AUX for a device, press and release AUX first and then the devicebutton for the type of device to be programmed (TV, VCR, or Cable). The selecteddevice button will flash once.4. Release CODE SEARCH.5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100times at a rate of once per second).6. Once the device turns off, press and release ENTER.7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6...Hope this helps! Parsos215
    Sep 20, 2011 | RCA Universal Remote Control
    Trying to program a universal remote to scientific atlanta 8300hd cable box. I can't find code for remote
    If you have a URC-7800 the codes 0477, 0008, 0017 should work for the scientific atlanta cable box.
    Feb 05, 2010 | One For All URC-7800 Remote Control
    RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
    These are all of the codes I have for the RCA universal remote.
    Programming Your RCA Universal Remote.
    The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
    Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
    Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
    Jun 24, 2008 | RCA Universal Remote Control
    Remote codes
    URC-3220 One for All Big Easy 3 Universal Remote
    I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Symphonic TV & Scientific Atlanta Explorer 2000 cable box.
    Please review my Fixya Tip posts for:
    1. Searching for the proper codes, or
    2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
    I hope that helps.
    Dec 21, 2007 | Symphonic ST419E TV
    Microsoft Xbox 360 Universal Media Remote Logo
    631 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
