Question about Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher
Water doesn't drain dishwasher
Water doesn't drain
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool dishwasher Model DU1345XTVQO, Serial
Hello, Welcome to FixYa.
Based on your post I understand you have a drainage problem with a Whirlpool dishwasher. t
ypically with these machines having poor washing and incomplete draining it can be chalked up to obstructions in the sump assembly. Here's how to inspect it and clean it if necessary.
Try this link if you think you're not too confident. They aren't pros, but it is a good guide for accessing the sump assembly relatively easy. This combined with my tutorial you should be fine.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
NOTE: Pay particular attention to the area where I've placed the arrow. It is a back flow check valve and can get debris stuck in it allowing water to back flow into the sump after the drain cycle ends, hence you get water left behind.
The other thing to inspect is the drain. The proper drain should actually be tied up at least as hi as the top of the dishwasher and the closer to the machine the better, but if it drains into a sink or disposer right next to the machine as long as it is tied up under the sink it should be fine...you also want to rule out any kinks in the hose of course.
Now you'll need to run a "reset" test sequence to observe it's performance. Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the pump itself is at fault...we'll cross that bridge if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 24, 2011
mc1bean
  • 3053 Answers
SOURCE: whirlpool dishwasher ADP 4502 Water fills and
Hello, ryklien
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Drains but drum wont spin
see this probably causes:
see for glogged drain line
see the pump pulley frozen
slow drain, improve the drain see the attachement
May 08, 2012 | Washing Machines
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Daniel
Aug 27, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher Logo
22 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
