Question about Craftsman Garden
19.5 hp briggs & straton ride on how to remove 2 pistons
Taking motor a part how do i remove the pistons ?
  • Craftsman Master
  • 2,239 Answers
You need to remove the engine from the tractor. un bolt and lift the cylinder head off, remove the ring off bolts on the crankcase closure plate and remove, undo the big end bolts and push the con rod and piston out through the top of the cylinder
Posted on Apr 21, 2013
  • 246 Answers
SOURCE: coils keep burning out on 12.5 hp briggs &
Hello:
>>Have you Replaced the Coil with a New One?
>>If No, then Replace the COil and your Problem will be Corrected. The Ign Mosule inside the Coil is Heating Up and Shorting Out. This Causes the No Fire when Hot Problem.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
lester482529
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
  • 474 Answers
SOURCE: 15.5/42 manual & oil filter
may not have a filter.try briggsand sratton.com. you will need all the info off the data plate on the engine
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: what is the oil capacity of the briggs ans straton
Approximately 40 ounces. Put in a full quart first, then add about 1/4 of the second quart and start checking the dipstick until you are at the full mark. Each time you add more, let it run down into the engine for a minute or so before checking or you will get a false reading. If your engine has an oil filter and you changed it, figure about 2 extra ounces for the filter
Posted on Oct 10, 2009
bbreton
  • 437 Answers
SOURCE: need an ignition wiring diagram for a craftsman 14
Go to www.searspartsdirect.com. put in your model number, from under the seat and it will bring up parts list and diagrams for you.
Good day.
Posted on Oct 23, 2009
Backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Aug 14, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Starter motor can't turn engine through compression stroke
valves are out of adjustment. reset them and it will do fine.
Apr 07, 2017 | Yard Machines Garden
How do you remove an engine from a Craftsman dyt 4000 lawn tractor?
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Jun 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Craftsman LT1000 Tractor. It has a
if you have a model # 917.272672, you can download a free user manual at
http://www.craftsmanlawn.com/Tractors-Riding-Lawnmowers/917.272673/
Oct 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need an ignition wiring diagram for a craftsman 14 hp briggs & straton riding mower
Good day.
Oct 23, 2009 | Craftsman Garden
Sep 13, 2009 | Garden
Jul 15, 2009 | Mtd Garden
Garden Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
