Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
There should be a sticker or plate mounted on the door jam of the unit that will say what the wattage is. if not, contact the manufacturer with the model number and they'll be able to tell you.
The output wattage is 1100 watts. It can be found on the second page of the operating instruction manual. If you don't have one, you can download it at retrevo.com, just enter the model number and get a pdf of the manual. Hope this helps you.
hi, you are correct it is 950 watts as you have read this on the microwave itself, when they sold these they kept the same model number but as they bought newer ones out the wattage increased so they kept the same number so its nothing to worry about it was just yours must have been a newer model then the first ones they made.
the first ones they made started at 700 then they did an 850 then a 950 so you are right its just a case of giving the same model number as the only difference is the wattage everything else is exactly the same, you wouldnt tell the difference if you had them side by side as its only the wattage that changed on this model
I've never heard of a microwave that lets you change the cooking power output. The magnetron tube that produces the microwaves only has off or on modes. No "low wattage" mode.
The "percentage cooking power" adjustments you can make on the control panel only cycle the microwaves on and off to reduce the amount of time the oven is actually cooking.
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
