Question about Canon ImageRunner 3320N Copier
Black dots on copies.
When printing out envelopes or printing using the copier, there are these random black dots speckled on the finished product (either the envelope or the paper that was printed out). How do you fix it? It's obviously not coming from the glass being dirty, because both of these objects are being sent to the copier from the computer.
  • 62 Answers
Try using the roller cleaning or wire cleaning procedure in additional functions. If fault persists, it might be toner build up on the fuser roller from dots worn onto the surface on the fuser rollers.
Posted on Aug 11, 2007
SOURCE:
Ink is smudged on envelope. How do I stop that from happening?
i bet you're printing in Black,
what happens is when black is selected, the 3 colored drums lift up 2 mm annd only the K drum is engaged, amd there is no static in the transfer belt under the CMY drums.
envelopes have air in them and can bounce along the bely after the black has printed, and seeing the toner is powder and not yet fused on, the toner touches the cyan drum as the envelope hits the fuser entry point as well as dragging on the Left transfer belt Blue lift handle(take out the belt and spring the handle off).
If you open the lid in this print mode, and lift out the cyan drum, turn it over and pull back the cover for the OPC drum, you will see the black toner on the green drum.
FIX 1. In the art work place a tiny dot of yellow. this will run the print mode in color and enagage all the drums. gaurantee your print will be fine, and know one ever sees that yellow dot.Problem is, this then runs down your CMY drums for black only printing.
FIX2.
If you have a later machine, downlaod iQueue from Xante.com (free) fantastic software. and get the machine updated with the latest X1.11 firmware from your dealer.
This allows with iQueue, to set the machine to print Black only, and you run the machine without the CMY drums installed....it works, it's great...
Aug 10, 2010 | Xante Ilumina Digital Color Press Printer
Speckles all over the page
This is happence due to bad Drom/tonner. Please replace it.
Sachidanand
Apr 13, 2010 | Brother HL-2170W Laser Printer
Hi i have a mfc 210-c & the yellow wont print , i get 3/4 dots i have tried to clean with no luck
Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
With full, new cartridge, test print only shows 6-10 dots. Cleaning repeatedly does not fix.
Nov 19, 2009 | Brother Multi-Function Center MFC-240C...
Won't print envelopes in black
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Apr 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
White spots with a black dot in the centre
pls check the ibt belt. its geting any hole are bunch its come like this, or u will check and clean ibt assemply transfer rolleres. and 2nd btr also.
Jul 23, 2008 | Xerox DocuColor 12 Color Copier
Print poor copy quality
Fuser pressure (2 green levers on fusing section) may be set to envelope position.
Mar 04, 2008 | Konica Minolta bizhub C250 All-In-One...
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
145 people viewed this question
Clive
Clive
old marine
old marine
Ekse
