Question about Creative Labs FourPointSurround FPS1800 Computer Speakers
Bad power plug going to woofer can i replace
Plug coming from ac adapter going to woofer has a short
    Top Expert:
  • Creative Labs Master
  • 44,097 Answers
The plug can be replaced. Radio Shack might be a source for a replacement plug
Posted on Apr 21, 2013
Dell latitude d520 starts with battery but not with ac adaptor
It could be a bad adapter, a short that drags everything down when plugged in.. could be a short inside the computer doing the same thing.
Borrow an adapter to see if you get the same result, if a friend or shop will help you with that.
A digital VOM could tell you if the right voltage is being put out by the adapter. Read on it, if it's supposed to be DC voltage and you get AC, the adapter is bad.
Oct 02, 2017 | Dell Latitude D520 Notebook
Laptop wont switch on even when charger plugged in
I recommend to him not to do it because him lapto it is possible to put in shortly and is not going to ignite
Aug 31, 2011 | Toshiba Computers & Internet
I got a compaq c36 it was working fine but now it wont switch on or anything do you now what it could be
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on, then you can be sure you have a bad DC jack or a bad AC adapter.
Mar 01, 2011 | Computers & Internet
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
My D-Link Router was working OK for the last 3 years, I just removed the Cables to clean the work station and reconnected. (1) With proper connection Lights did not come -up in short no power to the...
If you plug the AC adapter into a live AC outlet and the correct port on the router the power light should come on. If it does not either your AC adapter has failed or the router itself. You do not need to connect anything else for it to power on.
If AC power checks out then you need the replace the AC adapter or router.
Oct 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
Laptop will not come back on
Take the battery out of the laptop and only hook up the AC Adapter, if it turns on then that means the battery is shorted out and would need to be replaced.
If the laptop still doesn't turn on with just the AC Adapter, look to see if there is a LED Light on the AC Adapter, if the light isn't on when the adapter is plugged in then that means the adapter is bad and would need to be replaced.
If there is no LED indicator on your laptop then try another AC Adapter, if the laptop still doesn't turn on then that means your motherboard is bad and would need to be replaced.
Jun 01, 2010 | Panasonic Toughbook CF-73 Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
Laptop not powering
Sir,
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOWPUT IN BATTERY
AC power adapter How the AC adapter worksThe most common type of AC power adapter involves a small box, withone wire to go to the computer and another wire to go to the wall.There is usually an LED light on it, to tell you that it is on. (Is itlit on yours?) By the way, Apple notebook power adapters often have anLED that is actually built into the side of the computer, not into theadapter box, so obviously it won't light up when it's not connected tothe computer.
The power adapter box does several things. It lowers the voltage from the wall's 120 volts AC to typically 19 volts DC (it will be labeled with the exact voltage). It includes some power noise filtering. It often includes an automatic circuit breaker or overload detection. If this gets tripped, you can generallyreset it if you unplug it from everything for a few minutes.
You can measure the voltages on your AC adapter with a multimeter. When it is unplugged from the computer but still plugged in to the wall,it is normal to find that the voltage may be 1 to 3 volts higher than theprinted output rating.
Troubleshooting: AC Power adapter LED is off when you plug the adapter into the wall but not into the computerHas it been overloaded? Is the power strip turned on / is the outlet working? Is the cord from the adapter to the wall fully plugged in on both ends (try wiggling)?Your adapter may be fried- try borrowing an indentical adapter from a friendand seeing if that one will work in it's place (but do not plug it in to your computer, or you might fry your friend's adapter).
Troubleshooting: Check output voltages with a volt meter/multimeterFor those of you with circular connectors, your task is easy. Measure the voltage between the inside and theoutside. A diagram on the adapter's label will tell you which should be positive and negative
For those of you with the 3-pin Dell power connectors, I don't have a diagram for you yet, sorry.If you try measuring each of the three possible pairs of pins, you should get 20 volts between oneof the pairs.
Power distribution inside the laptop How laptop power distribution worksvoltregulator.jpgOkay, the power comes into the plug on the back of the computer. This connects it to metal tracesinside the mainboard of the computer. These will be connected to voltage regulatorswhich often output 5 volts, 12 volts, 3.3 volts, and the CPU voltage; they sometimes look like the image at right.
These will be connected to cylindrical capacitors distributed throughout the mainboard. Capacitorsact like tiny, fast batteries, supplying extra power where needed to maintain a steady voltage during high demand.
Finally, power goes to all the devices that need it.
Power for the LCD display is usually done seperately. Generally, LCD backlights require high voltage to operate.A component that might be called a power inverter will step the voltage upto what is needed for the backlight. Sometimes this inverter is a discrete andreplacable component, and sometimes just a chip on your mainboard. It is also involved in the brightness control.
The battery is an important part. It supplys power to theinput-side of the voltage regulators, just like the power from the AC adapter.Additionally, there is a charging circuit, which uses the power from theAC adapter prior to the voltage regulators, to charge the battery. (By the way, this is why the AC adapter voltage is always rated higher than the battery's rated volatge-- you need higher voltage for charging.)
There is a separate page exclusively for Laptop Battery Problems.
Short circuitsAnywhere in your laptop, physical or electrical damage can cause a short circuit.A short circuit will consume all available power, causing your laptop to not turn on.If your power adapter LED comes on when you plug it into the wall, but then goes offwhen you plug in the laptop, you probably have a short circuit.
Troubleshooting short circuitsAn ohm-meter / multimeter will read less than ~3 ohms when you measure theresistance between sides of power going into a short circuit. When measureing betweenthen power pins going into the back of your computer, consider the 2 pins whereyou expect voltage to be applied by the AC adapter. If the resistance indicatesa short circuit, this is bad.
A common trick to help isolate possible problems is to try to removing anything that mightbe a short circuit. Take out the battery, the hard drive, the DVD/CD drive, the floppy drive, PCMCIA cards, USB devices,miniPCI cards. See if the computer will then turn on.
You might have luck with a thermal imager (see story below) to find a hot spot caused by theshort circuit.
Spilled liquidLaptops exposed to small amounts of spilled liquid are repairable in some cases. Liquid can cause the following types of damage:
  • Short circuit due to wet liquid (problem goes away after liquid evaporates)
  • Short circuit due to dried liquid residue
  • Corrosion (especially bad with soda such as Coke or Pepsi)
  • Electronic components damanged by above short circuits
Immediately when a spill occurs, you typically want to turn off thelaptop, turn the laptop upside down (so the liquid goes out the sameway it came in), remove the power and battery, and allow to dry atleast overnight.
To remove dried liquid residue: Try removing the keyboard andcleaning any components that have dried liquid, by using distilledwater and Q-tips.
Computer turns off randomlyYour computer can turn off due to: power overload in the AC adapter,overheated processor / clogged fan,overheated battery, pushing the power button, Windows telling it to,the BIOS telling it to, loose wires (especially the power cord), orintermittent short circuits.
The most common problem is cooling. Try going somewhere air conditioned. Notice if the fan isbroken or clogged with dust (common older HP problem).
Thanks
Good Luck
Aug 17, 2009 | HP6710b 2.1GHz 15.4 160GB 5400 PC...
Battery or ac adapter problems?
Sounds like you were cheated out of your money. Hopefully you just need to replace you Power Supply Cord and it will work fine because my guess it has broken wires and that caused the shutdown. If this does nit work, Your motherboard has been short circuited and this will never be fixed, it needs to be replaced and this is costly so it may be better to get whole new laptop. Buy a new Power cord and maybe a new battery if you feel you need to, but if they don't work, your laptop is dead
Nov 21, 2008 | HP Compaq Evo n610c Notebook
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Creative Labs FourPointSurround FPS1800 Computer Speakers Logo
54 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
