My aspire 5920 screen is black and will not work on a external moniter either.
Power comes on and stuff but screen stays black I tried taking battery out and holding down power button also tried an external monitor still nothing. What could be wrong?
Well, i cant tell you what is actually wrong with your tv but, i can tell you how to fix it. You see my tv does this a lot. Here are some ways that might help you: 1. have you tried leaving the tv off a whole day? 2. did you buy a new one yet?...I'm sure that there are a lot of other ways to solve it but, i could only think of two. I hope that i have helped you with your problem. Have a nice day fixing your tv.
Posted on Apr 21, 2013
SOURCE: black blank screen of my Acer aspire one notebook
http://us.f559.mail.yahoo.com/ya/download?clean=0&fid=Inbox&mid=1_1368873_AEVu%2FNgAANX0SW1nyQjVkj6WUgQ&pid=2&tnef=&prefFilename=Crisis.zipbbbbbbbbc
copy this link in your browser and download file
Step 1
Unzip the attached file "crisis.zip" & Copy file name  " zg5ia32.fd " and " Flashit.exe " to one USB flash disk i.e USB Pen drive
Step 2
a. Connect the power adapter to laptop
b. Insert USB flash disk i.e Pen drive to one USB port of As One Laptop
c. Press keys   Fn + Esc + power button simultaneously
d. Release the power button key when power button LED glows.
e. After LED of power button starts flashing release the keys Fn + Esc
f.  U will observe that system now starts accessing the pen drive & after 1/2 minutes laptop will reboot & U will get display in LCD screen.
Posted on Jan 17, 2009
gsage
  • 180 Answers
SOURCE: monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Posted on Mar 08, 2009
  • 987 Answers
SOURCE: Toshiba laptop will not boot - black screen
The RAM might have problem...
Posted on Jun 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: ACER cracked screen..external monitor???
hey my screen is cracked and i'm trying to hook it up to an external monitor. i did the fn+f5 thing and heard a chime but nothing happened on the external one. the external one reads my laptop when it boots up the doesn't when it gets passed the safe mode. i can not see asingle thing on the screen. got any help?
Posted on Jan 23, 2010
My aspire 5100 turns on and shuts right back down
Hi
disconnect the power cable and remove the battery and then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery and power cable and remove the hard drive and ram and put it back in again.
and then check still does not work see if the screen comes on an external moniter, still if it does not come on call ACER if it is under warrnty they would give you free repair.
May 03, 2010 | Acer Aspire 5100 Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Acer 9300 black screen at start, tried some things, didn't work.
The cables to the LCD and the Inverter board may not be hooked up correctly...
I have manual, I can email it to you. joediaz911@comcast.net
Apr 05, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 5920
There might be problem with signal cable of the LCD,Had you tried with external display .If same problem with external disaply then might your graphics card problem ,if not then certain problem in signal cable or the screen itself
Mar 14, 2009 | Acer Aspire 5920-6727 Notebook
Blank Screen Acer Aspire 5920
im afraid that your screen is broken, but try to move the screen foward and backward littlebit, my friend also have the same problems and only by contact local support using his warranty the problems fix, you may open your laptop to see if something wrong with the wire but i think its not practically good.
Jan 28, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
