Question about The Singing Machine Singing Machine STVG1009 Pedestal Karaoke System Tower Speakers Camera Monitor and Radio
Need new power cord
Where can I get a replacement power cord?
I turn on my XP 50 Roland I can play for a little bit but then it turns off on off on need help to fix it
if your saying the power goes on/off allot then its got to be your power cord or connector in the back , these do have a hard life as these get moved around a bit , its gonna take a pro repair to replace the power connector-but you can buy new cords for them , try to wiggle it to confirm that's it , but if your display just goes on off , this is a software problem as most likely a error in reading the drive
May 12, 2016 | Roland Music
Korg c800
In the past, whenever I needed a specialized replacement cord (as an electrical engineer) I went to this company:
North American and International AC power cords and cord sets from... I have been able to find anything I ever looked for, and I see they have no minimum order. Another alternative is to find a local Goodwill or consignment store and browse through their older electronics (and hot plates and such). Old stuff sells so cheaply it's worth it just for the cord.
Nov 05, 2017 | Music
How to replace fuse in case it blows..?
The answer is you DON'T replace it without repairing the cause, lest you cause further damage to the internal components. Often the fuse is contained in a plastic "boat" that is right alongside where the power cord plugs in. You have to remove the cord to lift the tab on the boat.
May 04, 2011 | Behringer Ultratone K1800fx 180w Keyboard...
I need to buy a new power cord, but can't find one online. Help?
Almost ALL new electronic equipment use the same style cord now... You can find them at computer parts stores... but here is a HINT: You can usually find them at Thrift stores!
Dec 24, 2010 | Peavey ValveKing 100w All Tube 212 Combo...
I have a CTK-518 Casio Keyboard unit, second-hand. The DC Jack went out on it--the metal rod that makes the connection with the adapter simply broke off. So I purchased a new part and installed it,...
You probably got the WRONG type of jack. Thes jacks have different sizes, including the pin. You probably got one with a smaller sized pin.
These are really a pain to make sure you got the right one.
If you can, verify the pin diameter with a caliper.
ALSO verify the adapter is putting out power FIRST. The forces that broke the jack MAY have destroyed the plug on the cord from the adapter or brolen the cord. Use a voltmeter to verify operation.
If cord is broken, get new plug and replace the plug on the cord that plugs into the unit.
May 03, 2010 | Casio Music
Power problem. not sure if it is the cord or the plug.
You need to use a voltmeter to test the cord and plug.
Often cords break at flexure points. Plugs can be replaced.
You sometimes can get the culprit to show itself by pushing the cord together at points that seem weak or soft.
Oct 11, 2009 | Zoom Music
My Marshall 8040 has a sort of static sound. It started a week ago and I noticed that if I press the power cord hard into the amp, the static sound disappears. However, once I let go, the static returns....
It sounds as if you need to replace the power cord or the power socket on your amplifier.
If you can get into the cord check to see if the connections are tight do the same on the socket.
I guess you have a faulty connection.
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Music
The drum machine goes on and off, and I think the problem is at the connection from the power cord into the SR16. I think I need a new power cord.Or is there an internal problem at the connection?
It sounds like the adapter jack in the Alesis has a bad solder joint to the circuit board .This is a fairly common problem with all modules that have external power supplies and is an easy fix if you feel confident and are good at soldering.
May 16, 2009 | Alesis Sr 16 Stereo Drum Machine
Need to install new power cord
The black wire is in series with the power switch as it is hot. Use considerable care when working with A.C. If you are replacing cords, try to cut the wires off leaving some colored insulation so you know which is which. Always do these repairs with the power disconnected.
Apr 07, 2009 | Music
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
The Singing Machine Singing Machine STVG1009 Pedestal Karaoke System Tower Speakers Camera Monitor and Radio Logo
64 people viewed this question
Top The Singing Machine Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a The Singing Machine Music Expert? Answer questions, earn points and help others
