Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
GE Nautilus Dishwasher - NO water coming in at beginning
GE Nautilus Dishwasher (Built-in/Model #?) NO water coming in at beginning of cycle. Cycle completes BUT nothing gets washed. Machine acts like it is running normally EXCEPT for lack of water. I am NOT mechanically inclined however I am willing to follow directions - Is this a clogged water valve? How do I get to it to unclog it? Do I need to read an owners manual - is there one available online?
    Novelist:
  • 159 Answers
All fill cycles on a dishwasher is timed. so at the end of the fill cycle the dishwasher may run. the first thing I would check is to make sure the water inlet valve is good. for this you will need a volt/ohm meter. you will want to make sure that there is 120v going to the valve. if there is you then would want to remove the wire connector on the valve and ohm it out. if you get a reading anywhere from maybe 450-650 the valve should be good and you will want to check for a blockage. good luck
Posted on Aug 04, 2007
  • 641 Answers
Normally,if water doesn't come in, cycle should not go on ! Add water by hand to tub and operate the dishwasher. Let us know with your results and we will see how could we assist you.
GE Nautilus- model GSD3400G00WW. Why is there standing water after the dishwasher has completed it's cycle?
i won,t too buy a g.e. dish washer model.gsd3400g00ww where can i find this model and how much it cost.
Nov 10, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher. Main Soap dispenser still has soap at end of cycle
Raise your hot water temperature to at least 140 degrees, try using FINISH tablets.
Jan 09, 2010 | GE Nautilus 24" Built-in Dishwasher
Our dishwasher is linking suds after the cycle begins BUT ONLY 1 of 10 loads does this happen. What could cause this problem? Thank you.
Use dry powder soap and just enough to clean the dishes. Usually around 2 tablespoons is enough in a modern dishwasher and soft water after giving the dishes a good scrape. If you prerinse, use much less soap!
Dec 10, 2009 | GE Nautilus 24" Built-in Dishwasher
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap and water coming out the front of the dishwasher
I would think that the gasket is not doing the job, can you pull the gasket together to decrease the gap. If not then try another gasket if it's not on warrentee
Apr 18, 2009 | GE Nautilus 24" Built-in Dishwasher
2 year old GE Nautilus dishwasher
Check the pump, make sure it is working properly and pumping water out. If it is then check the drain hose and make sure it is not plugged.
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Soap does not dissolve
What is happening, is that your dishes are washing dry. Start the dishwasher and slowly turn the timer till it starts to fill. Let it go and see how they are after
Jun 20, 2008 | GE Nautilus 24" Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
468 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
