Question about Canon IXUS 860 IS Digital Camera
Where can I buy a Canon Ixus 860 IS replacement screen?
The 860 IS screen has some dead pixels but the camera still takes great pictures
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 848 Answers
Where can I buy a Canon Ixus 860 IS replacement screen? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0100B Lien Chang 860 ALZ GJ712D EH Power Supply Backlight Inverter
Posted on Mar 22, 2015
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The IXUS 860 IS is called the SD870 IS in some parts of the world. You may order an SD870 IS LCD assembly from here.
Posted on Apr 21, 2013
mcomijohns
  • 477 Answers
SOURCE: user manual for canon ixus 860
Hope this helps
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=15655
Posted on Apr 25, 2008
SOURCE: back spot on canon ixus 860 screen
Well, not sure if you got it resolved yet but the same thing happened to me. Brought it back and got it fixed under warranty. You'll most likely see more gray circles appear over time. They don't affect the picture but they are annoying.
Cheers
Dan
Posted on Apr 23, 2009
samrat_babui
  • 296 Answers
SOURCE: Canon Ixus 860 lens
hi
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are within warranty period and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
all the best.
thankyou.
Posted on May 05, 2009
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
regards iversh
a very helpful rating is apreciated for answering ur query.....
Posted on Aug 19, 2009
SOURCE: lens error
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
Posted on Oct 15, 2009
Black spot screen
What sort of black circles? Are they dead pixels I wonder?
Dec 03, 2013 | Canon IXUS 860 IS Digital Camera
DISPLAY LCD~ Canon IXUS 860 ISWhat's your problem?
ldc as gone blank.can not see photos when i take a photo
Oct 28, 2012 | Canon IXUS 860 IS Digital Camera
When i take picture it isnt clear.
may be is a Lens failure.
Replace and continue using it.
You can buy on www.ebay.com new or used in chep prices
If the answer is helpful, rate my answers
Sep 20, 2011 | Canon IXUS 860 IS Digital Camera
Change the lens of my Canon IXUS 860 IS
remove the cover screews then discharge the flash capacitor take precautions of static electricity.Remove the screews of the mother board and the lens-body .detache the lens unit to replace with a new one.if u need note down the fixing positions etc.
Apr 10, 2010 | Canon IXUS 860 IS Digital Camera
Back spot on canon ixus 860 screen
Cheers
Dan
Feb 07, 2009 | Canon IXUS 860 IS Digital Camera
A week ago I purchased a Canon Ixus 970 digital camera. When using in dark conditions yesterday, I noticed two bright blue dots on the LCD screen. I've switched the camara off and on again and have...
You could try taking it back to the store if the (what seems like) the dead pixels are "distracting" you or "annoying" and if you are lucky you might get it exchanged.
It partially depends on the amount of the dead pixels present as for an LCD screen to be classed as being defective 0.01% of all of the pixels on the screen must be "dead".
God luck if you will try to exchange it.
Nov 07, 2008 | Canon Cameras
Lens error
Oct 23, 2008 | Canon IXUS 860 IS Digital Camera
Canon IXUS 860 IS Digital Camera Logo
147 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
