Question about Ariston Technologies Dishwashers
MY Ariston LSI 61 doesn't start
The program light on the left is always on even if I don't press the program button but the dishwasher doesn't start. A few days ago there was water left on the lower tray and there has been a short circuit. What can I do?
5 Suggested Answers
SOURCE: my ariston LSI 61 water
the tray under the machine is filled with water and needs to be emptied
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Posted on Jan 14, 2010
  • 901 Answers
SOURCE: my Ariston LSI 45/50 makes a loud bang during the cycle
hope your dishes are firm in it's seating.
Posted on May 03, 2010
Macmarkus
  • 2605 Answers
SOURCE: On a Kenmore dishwasher with
Hello, Welcome to FixYa.
There likely is a blockage in the filter/screen and chopper assembly below in the sump well, it's just not obvious/visible. The place to look for a remedy is the wash pump area, you`ll need to follow these steps to clean it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Mar 17, 2011
LBF 51 flashing lights
Hi
Is this the first time you are operating your dishwasher or if you have already operated it before go for the instruction manual of your machine which could possibly solve your problem.If you don't have the instruction manual don't worry i have attached a PDF of the manual go through it.Hope it solves your problem.If it doesn't i would recommend calling the technician to avoid further problems.If any other issue occurs please reply.Please rate me if my solution helped you.
You could have your instruction manual here.just click on this link.
http://www.dishwasher-manual.com/manuals/hotpoint-ariston/Hotpoint-Ariston_LBF_51.pdf
Regards,
bonefirediv.
Apr 12, 2014 | Ariston Technologies Dishwashers
Ariston L63 dishwasher stopped mid cycle with water in base.
Jun 16, 2009 | Ariston Technologies L63 Free-Standing...
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
Used some washing up liquid instead of dishwasher tablets, after i got rid of all the bubbles and drained it, it no longer starts. If i switch the power off and leave it for a few minutes i can select a...
dear sir vif you have used liquid soap in your dishwasher it will make mountains of bubles to kill all bubles outin a hurry take a sos pad put it in your machine and run the dishwaser this will remove all of the soao instantly try it it really works i am in the dishwasher bussiness and it does work thanks from gilles
Mar 15, 2009 | Ariston Technologies Dishwashers
My ariston LSI 61 water pump is on all the time and the left hand program on top of the door is flashing
Oct 21, 2008 | Dishwashers
Ariston Dishwasher LI 675 DUO
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
Sep 16, 2008 | Ariston Technologies LI640S Dishwasher
Ariston LL64 error
call 1800 815 589 ariston australia
Jul 06, 2007 | Ariston Technologies LL64WNA Built-in...
Ariston LL64 doesn't start
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
Dishwashers Logo
66 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
