Question about GE Washing Machines
WHDSR315DDWW won't advance to next cycle unless i do it manually
Washer won't advance to next cycle but works fine if I set it manually.
  • 12 Answers
SOURCE: washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Posted on Nov 22, 2008
SOURCE: My Kenmore Washer 110.92281100 won't stop
I purchased a new timer, installed and solved the issue.
Posted on May 14, 2009
oldTech2332
  • 2341 Answers
SOURCE: maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Posted on Nov 04, 2011
ercupa190
  • 12223 Answers
SOURCE: My GE whdsr316g1ww will freezes during the 'Cottons' cycle
please see the next step and use the common sense: God bless you
Lid Switch
This is the most common reason for the washer not spinning or agitating. This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub
Posted on Aug 02, 2012
richroth
  • 9472 Answers
SOURCE: my washer is not performing all the cycles unless I manually turn the dial to it including draining
The timer motor has failed and needs to be replaced. Here is a link to the part.
Posted on Oct 20, 2012
Digital timer stuck on 10 min.won't start the spin cycle
I know this isn't the solution you were hoping for but here is the manual for your machine:
http://www.samsung.com/ca/consumer/home-appliances/washers-dryers/washers/WF203ANW/XAC-supportforward
You say it rotates L & R...do you mean it agitates but the timer isn't advancing?
Dec 30, 2012 | Samsung WF203ANW Front Load Washer
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
when on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Sep 24, 2011 | Roper Dryers
My friend has an xqg65-11 all in one that she bought used. It worked fine for a few weeks, then started to not move to the next cycle, it just stopped. She has been manually clicking it to the next cycle....
There is a lint filter right under your washer door. You push that lid open, and you will find the lint filter. I have the same machine. but min is an xqg50-11. Is that a washer/dryer combo?
Jul 20, 2011 | Haier XQG50-11 Front Load Washer / Dryer
My Kenmore washer will not move into the next cycle unless I manually turn it to the next cycle. This just began today. What is wrong with it?
It's either the timer is faulty or the lid switch is broken. If it fills and agitates but dos not spin and drain it's the lid switch. If it spins and drains when manually advanced to that setting your timer is bad.
May 18, 2011 | Kenmore Washing Machines
May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washing Machines Logo
19 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
