Question about Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front Load Washer - White
How do i align the door strike on my whirlpool duet washer WFW9150WW01 and it wont lock
  • 67 Answers
SOURCE: whirlpool duet washer
is there an error code?
Posted on Mar 27, 2007
Lumpy816
  • 246 Answers
SOURCE: whirlpool duet sport frontloader washer, door wont open, locked up.
Not a problem glad we could help.
Posted on Jul 11, 2008
SOURCE: Whirlpool Duet Washer - "Door Locked"
check wiring to switch.
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
Whirlpool washer model wfw9150ww01 code f2e3
Watch this video:
http://www.youtube.com/watch?v=W1ceH7TKkoE
Jan 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet wfw9150 ww 01Not spin after it drain?? it beep sound with Door lock and Wash light on
First, check to be sure the drain filter is clear. Also, pull the bottom of the door boot aside and look down in there to be sure an article of clothing didn't get in there.
Nov 26, 2012 | Whirlpool duet Washing Machines
WFW9200SQ00 Whirlpool washing machine. Door strike doesn't go in the latch, seems a mechanical issue. There is a little white pin inside the latch on the way. Any ideas what can be wrong?
Does the door strike seem to be broken and is that what you see inside of the latch asm.? if no the strike is ok i suspect the latch itself has broken apart and your seeing a internal part of it through the opening where the strike fits into, in which case the latch/lock assambly would need to be replaced.
The part numbers are
DOOR LATCH ASM. 8183270
DOOR STRIKE W10217552
GENE
Oct 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
On my whirlpool duet washer the little pin in the door (black) that pushes in when shut broke and now my washer wont kick on
Is this pin on the door or the frame? If the frame then you need a new door lock assembly that you replace by peeling back the rubber tub bellow after removing retainer spring.
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer caught on fire have you had this happen to any other whirlpool Duet washers
My LG washer caught on fire last week, but it was due to a lightning strike which took out a garage door opener and a couple of GFI outlets. Did you have any storms in the area?
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
Here is a tip that will tell you how you can get your washing machine unlocked manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front Load Washer - White Logo
Dan Webster
Dan Webster
Sal DeAngelo
