Question about Asko 1375 Dishwasher
D3112 Asko smells
Bad smell come from glasses when you drink and put your head in dishwasher and it is same smell. How do I clean it?
markevans
  • 148 Answers
SOURCE: diswasher asko d1716
clean out the food traps in the bottom, assuming the unit has some sort of filter.
then run a cup of bleach in the unit with no dishes. you might need to do this once or twice.
make sure you use fresh bleach.
most bleach dies in strength after only 2 weeks. it will still smell like bleach to some degree, but it will have little effect. most bleach manufacturers add 'scents' to the bleach to hide the degradation characteristics of bleach.
also, you may have a partially blocked air gap.
to determine this, check for water remaining in the bottom of the tub after it drains. left over water will contribute to odor, and negate any sterilization you dishwasher might otherwise try to do.
good luck
mark
Posted on Dec 28, 2007
  • 24 Answers
SOURCE: ASKO D3350 Dishwasher won't work.
possible failure of electronic board expensive to fix. May even be suprresion capacitor. A lot of brands used suppression caps on the ac input to filter out unwanted noise. When these blow they stink and some even arc but one thing is sure they cut the power to the rest of the dwasher may even throw out your power.Make sure it is switched off and unplugged before dismantling it.
Posted on Oct 08, 2008
  • 42 Answers
SOURCE: Overfill Protection tripped on ASKO D3112 dishwasher
remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
Posted on Dec 21, 2008
  • 93 Answers
SOURCE: My asko 3122 dishwasher never heats up
Sounds as though the element burned out I would suggest you have a qualified technition out to confirm and replace so he\she can inspect the machine and see if there is indeed another fualt,the element can blow for a number of reasons but like a light bulb blowing it is electrical and can go at any time,I would not suggest you attempt the repair by yourself unless you have some sort of experiance with this type of thing.
Posted on Jan 23, 2009
SOURCE: strange odour from dishwasher.
There was a recall of this model for fire hazard - the recall is still in effect
Posted on Sep 04, 2009
Why does samsung dishwashers stink?
numerous possible reasons, are you using it as a waste disposal unit, doing regular services washes, washing at the right temperature, cleaning the filter often enough, using the right detergent?
Sep 18, 2014 | Samsung Dishwashers
Why does it always have a bad smell
I noticed our old Asko 1473 had also been smelling for a while. I needed tor replace the seal on the bottom of the door as it was well past its best by date. There was a lot of smelly gunk behind it which I removed when replacing the seal. It now has no bad smells. I had to pull the door apart in this model to clean it out.
Jun 26, 2014 | Asko Dishwashers
My drinking glasses have a bad smell. Bought all new glasses and the same problem, coffee cups and mugs are fine it is only the glasses any suggestions
If it smells like sulfur? You may need to add a filtration system to your house, Or get a plumber to check the anoid rod in the water heater. It may need replacing.
Jan 06, 2010 | Dishwashers
Drain motor runs all the time. flashing "glass" light , (overfill switch tripped ) but drain system now clear. How to reset. I am 5 hours (return trip) by car to nearest city.
used a (new, clean) plumber's helper to force air through the drain system. The pumping action removed the water from the sensor and back in business.
Oct 31, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
There is an Asko D3112 on our office. I've been
it is programmed to continue where it left off. It is best to remove chunks of food from plates rather than rely upon the rinse system.
Oct 10, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
When the load is in mid-wash it smells like a fish cannery! The whols house will smell like fish. The dishes will all smell like fish. I put lemon and vinegar down the disposal and it worked for a few...
You might want to try adding a jar of "Tang" orange drink to the dishwasher and running it through a wash cycle.
Empty the washer, remove the racks.
Fill the soap dispenser with Tang and put the rest in the bottom of the washer.
Set the washer to run a normal wash cycle and when it is finished it will have cleaned out your dishwasher.
Now depending on how much debris is in the washer, you may have to do it twice.
Worked for me. Good luck.
Regards,
Jul 21, 2009 | Dishwashers
Lights blinking
I have a 3122 and had a similar problem, Lights flashing, humming noise and me standing there scratching my head! I emptied all the water out of the filter basket and then tilted the machine backwards (only needed about 20 degrees) and then the rest of the water drained all over the floor... about 1/2 a liter. Now its all good! and the missus is nun the wiser!
Jan 25, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Dishwasher smells like pond scum
I have the SAME problem with our dishwasher. It's disgusting. Between the fishy glasses and the garlicky ice cubes (NO, we don't have garlic in our refrigerator or freezer -- purchased ice doesn't smell), I'm embarrassed to pour our guests a glass of ice water!
Jun 05, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Diswasher asko d1716
good luck
mark
Dec 28, 2007 | Asko D1716 Built-in Dishwasher
Wont dry
make sure you select a high temp wash and the heated dry as well Also, dont put too many plastic items in there at once, they dont dry very well in anything. Check the amount of soap you are using, it shouldent be more than 2 tablespoons (way less than the dispenser can hold in otherwords. lastly, make sure the weater coming into your dishwasher is hot...you may need to turn up your water heater or run the kitchen faucet hot water til its hot before turning on the dishwasher. you said the fan is working, so i assume you can feel the air flow out of it at the lower left during the dry cycle. if you open the unit after its been running for a half hour or so, see how hot it is inside. Idf its not steaming, you may have a bad heater. Thats all I can think of off the top of my head. Hope this help!
Aug 19, 2007 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko 1375 Dishwasher Logo
63 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
