Question about Minn Kota Powerdrive V2 Bow Mount Trolling Motor with Foot Control Autopilot and Universal Sonar 2 (55 lb Thrust 54 Shaft)
I made the mistake of buying the powerdrive v2 minn kota motor with the i pilot not knowing that the foot pedal becomes useless after installing the i pilot had any one figured out how to outsmart th
Can i make both foot pedal and i pilot work together. so i don't have to change heads all the time
5 Suggested Answers
  • 3 Answers
SOURCE: Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
  • 5370 Answers
SOURCE: I have a 2007(ish) minn
The **** is due to motor.The motor is causing the ****.Check the trolling motor. If, while holding a heading, the ( auto pilot) AP motor steering system seems to "****" back and forth a few degrees it may be due to excessive gear "lash" or looseness in the steering gear system. -------- Step 1. To dampen this oscillation of the motor lower unit, make sure that the 2-piece aluminum stop collar on the motor shaft (between the lower shaft collar and motor bung) is firmly slid up against the lower shaft collar bushing and tightened in place. ------ Step 2. If problem persists, install new steering clutch gear system and steering motor output gear (P/N 2770215). -------- -------------- Pull the motor apart and see what everything looks like inside, bearings good, brushes moving in-out, brush holder not melted, wiring in good condition. The motors can be rebuilt.---------- There is service manual for minn kota powerdrive V2 with the foot control auto-pilot.To get service manual click this link below:--- http://technoanswers.blogspot.com/2011/06/minn-kota-repair-manual.html ------------------ This should help.Thanks.Helpmech.
Posted on Jun 12, 2011
  • 823 Answers
SOURCE: I have a minn kota
Ok, I have done this quite a few times so take heed, I am not familiar with the MK65 but I am sure the principal is the same on all of these motors..
Take off the top half of the plastic head and look on the center shaft. Your two foot control wires wrap around a plastic spool which sits on the shaft with a spline fit. If you have not done this before, get a pad and pencil and draw the way the wires come in, lay and attach in that plastic spool - because when you pull it off, if they come off you will be scratching your head wondering what the hell you did. You can figure it out but why think if you don't have to, its not as simple as it sounds because spool rotates, the wires wrap round and round etc.. Slack your cable tension adjustment screw in the footpedal all the way off, then what you have to do is slide that plastic spool off, and rotate it until you have the right position. The object of this, is to have the motor set pointing straight ahead, with your footpedal in the middle incline position, so you have full travel in each direction up and down. When you do this, you have to be aware that with the cables loose, they can come off the cams in the footpedal if you don't keep tension on them. Good luck.
Posted on Jun 20, 2011
Minn Kota Powerdrive V2 Foot Pedal complete
no we can not . try a dealer of them
Feb 22, 2017 | Sewing Machines
WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
Can get replacement parts for my Minn Kota trolling motor FAQs
Apr 13, 2016 | Minn Kota Boating
The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
Minn Kota Powerdrive V2 Bow Mount Trolling Motor with Foot Control Autopilot and Universal Sonar 2 (55 lb Thrust 54 Shaft) Logo
69 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
