Crosley Collegiate turntable changing the belt
How do you change the belt and take apart the Crosley Collegiate (CR6010A) Turntable?
djproaudio
  • 515 Answers
SOURCE: Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
SOURCE: Turntable does not turn
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Posted on Aug 07, 2009
  • 69 Answers
SOURCE: Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
Posted on Aug 08, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
Its playing the record to fast do i need to change the belt
Unlikely- it might be in the wrong position, but that could be caused by the belt being slack, in which case you would need to replace it. Check the belt is set up right and if it slips out again replace the belt. Otherwise look around inside for another cause. IE faulty power supply to the motor.
Apr 25, 2011 | Crosley Conductor CR73 Turntable
Crosley music centre has fault on record player due to turntable not working
If the unit is belt driven, (sometimes hidden) that is common cause of turntable failing to turn. Either belt comes off or is deteriorated.
Apr 27, 2010 | Crosley CR711-BK AutoRama Retro Turntable...
My turntable does not spin
On my Crosley there is a switch on the back for either Phono or Aux In. Make sure it is set to Phono or the turntable won't spin
Jan 08, 2010 | Crosley 0187SST Turntable
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
 Grubhead
Grubhead
