Question about John Deere Garden
How to relpace points on a john deere 318 onan motor
Wont start think we need to replace points need to no how
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Posted on May 19, 2009
  • 69 Answers
SOURCE: HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS
Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
  • 850 Answers
SOURCE: Is there a way to test the ignition condensor on
not worthtesting just replace it if its suspect as they are only cheap to buy & easy to fit
Posted on Jul 25, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
  • 110 Answers
SOURCE: I'm wanting to change points & condenser
At that age, it's highly likely that there aren't any! You don't say what engine is fitted, but if it's a Briggs or a Tecumseh, they went solid state in 1982. If that's the case, just replace the coil module.
Posted on May 12, 2010
How do you get to the starter bolts on a john deere 318 with onan B43G engine
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 29, 2017 | John Deere Garden
My 318 John Deere mower blades would not turnoff. The switch would not move. Even when I got off the seat the mower blades continued. I turned the motor off and now it won't start. Any idea?
Faulty attachmentment switch, replace it as it is sending a signal that it is engaged to your starter circuit, that is why it wont start.
It is also faulty as it wont engage the attachment (mower cutting deck)
Aug 03, 2015 | John Deere Garden
My John Deere 420 onan stops for no reason after running for ten minutes Restarts immediatly.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Jul 07, 2015 | John Deere Garden
John Deere 318 with an issue
black smoke is over fuelling and not spark related
check / clean carby especially the float, needle and seat area
Nov 23, 2017 | John Deere Garden
John deere 318 wiring diagram I replaced an bg 316 onan with an bg 318 onan new the starter only has one bolt for wires the old one has a bolt and a plug on where does the purple wire go on this new...
Sep 28, 2009 | John Deere Garden
I have a older mmodel 318 riding mower with an onan motor. wruns very well but when it is hot outside it will shut down withinabout a minute the power will reinitiate and the tractor can be restarted ....
possibly a carb or coil problem. does it have point type ignition? if so try replacing the condensor.if nothing else changes try replacing the fuel filter. then nothing,a float sticking in the carb or a bad coil.
Jul 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
438 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
