Question about Motorola Walkie Talkie 2-Way Radio
What's the best handheld radio that can operate at 40 Mhz? I have a motorola radius but no model in it. I learned from the technician that it operates at 40 Mhz. I want to purchase additional units but I dont know the equivalent brands or models compatible with the exixting units.
  • Roberta Smith
    Roberta Smith May 11, 2010
    what country are you in ?
  • John L radiodude365 Feb 09, 2013
    Agreed, plus Vertex has a few. They are rare. Send me a message, I have one.
  • Motorola Master
  • 1,654 Answers
Motorola makes a lowband model, the HT750 16 chan, 6 watt, which will do the 40 MHz band. For new it is a "local" dealer item or you would need to call your favorite mailorder Motorola dealer for pricing. (Advertising online for this radio restricts showing the price.) Or you might check eBay. Lowband is rare, so watch you are looking at the correct version of the HT750.
Posted on Mar 13, 2009
Can the freq 156,600 be put in this radio if so how do i do it
No, 156.600 MHz is not one of the 27 VHF frequencies available in the CP100 VHF radio. (If by chance you have a typo and you meant to ask about the common frequency of 154.600 MHz, aka green dot, it is available in the CP100 VHF.)
Here is a link to a website with the user guide:
http://www.essnashville.com/CP100-operationsmanual-021407.pdf The frequency chart is on page 34. Programming instructions begin on page 20.
Best regards.
Best regards.
Feb 09, 2014 | Motorola Radius Cp100 Uhf 1ch Two Way...
How to pair Motorola T4508 with Oregon Scientific TP391 ?
From what we can tell the TalkAbout T4508 is a non-USA version of the T4500. The T4508 operates in a frequency range from 409-410 MHz. Unlike the USA version which operates between 462-468 MHz.
And it looks like the TP391 operates around 466 MHz. User Guide: http://de.oregonscientific.com/ulimages/manuals2/tp391_EN.pdf
This being said, your radios might not be compatible.
Best regards.
Best regards.
Mar 03, 2013 | Motorola Talkabout T4500 (7 Channels)...
Motorola astro moblie programming !!!!!
"No longer supported" means they don't repair them at their repair depot anymore. However, software for most models is still available. All Motorola software is by subscription, and they choose who can obtain a subscription. You must be a Channel Partner (dealer) or meet their criteria for obtaining it.
Most 800 MHz radios are trunking radios, and require a tower system to operate. Many towers in this bandsplit have been shutdown or retired due to changes in the licensing/availability of 800 MHz frequencies.
If you are planning on operating the radios with a tower system, see the owner of the system for programming. If you are wanting to use the radios in simplex (radio-to-radio), you could get them programmed at a full-line Motorola dealer. You will need to provide your FCC assigned frequencies.
The model number you mention is incomplete, and I could not determine which of the softwares you might need.
Best regards.
Feb 07, 2013 | Motorola Astro Spectra 800mhz Mobile...
Will talkabout 250 communicate with cb
No. Your Talkabout T250 operates on FM UHF frequencies between 460-470 MHz. The CB operates on 40 frequencies between 26-27 MHz.
Best regards.
Oct 27, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
I bought walkie talkies with 56 km radius and yet we are lucky to reach each other after approx. 1 mile,any idea why we don't get the range
You do not mention the particular model of Motorola, so this answer will be generic in nature. Some Motorola TalkAbout radios have been factory programmed with a few GMRS repeater frequencies. These channels require the use of a repeater tower, which will 'repeat' what you say over a greater distance. It is possible you have this type of radio. Check your user guide, and then set your radio to the appropriate channel for the repeater in your area.
Radio-to-radio without the use of a repeater you can expect up to 2 miles line-of-sight out of most handheld radios. This distance is reduced by obstacles such as buildings, trees, etc. inbetween the radios. It can also be reduced if you do not hold the antenna of the radio perpendicular to the ground.
Best regards.
Jan 19, 2012 | Motorola Walkie Talkies 2-Way Radio
How can i get the frequency 130.00mhz - 150.00mhz from 75-822?
No. CB radios operate in the 27 MHz range and cannot be modified for out of band operation.
Feb 16, 2011 | Midland 75-822 40-Channels Handheld CB...
I just have Uniden Por510XL (used) but don't know how to set the channel (programming) so it can match with my handheld radio (i use motorola GP2000)
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Newbie here..Can anyone enlight me on a set of Motorola Radius P110 2-Way UHF Radios with Batteries and Holding Case. Is there any Value in them or should o=i Junk em? As I said I'm new to 2 way radio and...
The P110 is a construction grade 2-way radio. It was considered one of the best on the market during the 1990s. It came in several versions, including (but not limited to) VHF & UHF; 2 to 8 channels, 2 watt or 4/5 watt models. If your radios are in good working condition, they would be worth keeping. The only consumable would be the battery pack which needs replaced every 2-3 years. (Sidenote: You can check the battery age by looking for a 3 digit number on the battery. The first number is the year and the next two digits are the week of the year the battery was produced. ie. 945 would be either 2009 or 1999 the 45th week.)
Here is a link to the operator's guide for the P110: http://www.qsl.net/bg4aaf/user/motorola/p110S.pdf
Best regards.
Feb 07, 2010 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
I need help please
Make sure you have the CTTCS codes the same on each radio! Also PMR446 radio's wont be able to talk to GMRS radio's
Aug 30, 2009 | Midland 75-822 40-Channels Handheld CB...
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
Radio Communications Logo
211 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
