Question about Radio Shack Pro-97 Handheld Scanner
No sound from squelch and wont scan pro 79 scanner
I turn on scanner hear a faint crackling sound no matter were the squelch is turned and dont scan at all but all other functions work
5 Suggested Answers
SOURCE: Pro-95 scanner has stopped scanning
Shit I don't know.
Posted on Jan 26, 2008
SOURCE: Squelch is open all the time
I had the same problem on a pro-2096. Luckily I work at RadioShack, so I was able to send it out for repair for free. Our repair center replaced the PCB, and it works fine now.
Posted on Jul 08, 2008
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
  • 120 Answers
SOURCE: scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
Posted on Jan 10, 2009
Radio shack noaa desk scanners squelch sound unit wont scan
If the squelch is on, there can't be a loud noise. Either the sqelch is completely off or you are not tuned to a station. NOAA broadcasts are continuous, not intermittent
Oct 01, 2012 | Radio Shack Radio Communications
I have the pro 96 for about 2 years and I can hear the squelch sound but its not picking up chatter.
Try turning the squelch to minimum, press Scan, or you may have to program it. To program, Press PGM, select the channel you want, press PGM, use the number key and ./DELAY to enter the frequency including the decimal point you want to store, if you make a mistake press CLR, press the ENTER button to store it. You can get your frequency's for your state at www.RadioReference.com ...hope this was helpful..
May 15, 2010 | Radio Shack Pro-96 Scanner
Turn it on, press the manual button,then rotate the squelch knob until you hear silent,press scan and wait to see if you hear transmissions,if not ,you may need to re-program it, to re-program, press manual,enter the channel number,press manual,enter the frequency you want including the decimal point, press E. If you make a mistake,press CLR to erase. You can get the frequency for your state at RadioFreq.com or RadioReferance.com. hope this helps..
Mar 29, 2010 | Radio Shack Pro-96 Scanner
SCANS BUT WILL NOT ICK ANY CHANNELS AND HAS NO
Turn the scanner on and volume up all the way, turn the squelch until you hear static, then turn the squelch down slowly until its silent, press scan, has it ever been programed? Just a thought. hope this helps..
Mar 25, 2010 | Radio Shack Pro-94 Scanner
Not scannig right wont receive any signals radio shack pro-89
Turn scanner on, half volume,turn squelch untill silent,then push scan........hope this works for you.....
Mar 01, 2010 | Uniden BC60XLT-1 Handheld Scanner
I cant get my 350a to lock in on a channel when its scanning in the private mold.it will try sometimes but wont hold them. I can push the hold button and hear crystal clear in the private mold. help...
If you haven't already done so, while scanning in the PRIVATE mode, turn the SQUELCH control down slowly until scanning stops and you hear a hissing noise. Then turn the SQUELCH up slowly until scanning resumes. This should set the threshold so that the scanner will stop on an active frequency.
BillB
Jan 18, 2010 | Uniden BC350 Base Scanner
It just scans and scans it never picks anything up. No clue how to work this scanner or where to get codes for it. When you turn it on, it just scans thru all the channels but doesn't seem to pick anything...
Sounds like either your squelch is set too high or you don't have the proper frequencies for your area programmed into the scanner. When it starts scanning turn the squelch down gradually until the scanning stops and you hear noise, then turn up slowly until it starts to scan again. If you still don't pick up anything, you probably need to reprogram the frequencies. For a list of active frequencies and systems in your area visit
or
www.CityFreq.com
In case you need it, here's a link to the manual for your scanner.
If you have any other questions, please contact us again.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Radio Shack Pro-2051 Base Scanner
I have a new pr097 scanner and programed it fine but i get nothing recieved not even weather channel thay scan all fine but it dont stop on anything i cant figure it out also on my old scanner when you...
im just going to radio shack and return it for the only other one they have in stock which only goes to 512mhz whics stinks but at least i will recieve something wwhich is better than nothing
Dec 27, 2008 | Radio Shack Pro-97 Handheld Scanner
My pro-2018 won't scan anymore.
you may need to re program it and get a external antenna.i recommend that you get a scanner pc programming kit.
Jan 31, 2008 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-97 Handheld Scanner Logo
425 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
