Question about Gestetner A045 Wide Format Copier
In scanplot base software in A045 machine gives error when you run error is below You donot have memory access. Notice you have the instructions in user manual(RW-240 scanplot setting)? but i have checked it in manual but i didn't find any solution.
    Problem Solver:
  • 5 Answers
This requirement and solution are in the Plotbase manual, not the copier manual. See pp. 29-30 Setting for RW-240 ScanTool.
1. Start - Control Panel - Administrative Tools
2. Local Security Policy
3. Local Admin Policies
4. User Right Assignments
5. Lock Pages in Memory - Local Security Setting
4. Add User or Group, then Advanced
5. Add or Find Now - select users (all)
6. OK
7. close Local Security Setting windows
Posted on Aug 31, 2009
900 Firmware error on lexmark x544 what does this mean
Within your printer there is a micro-processor and a memory chip. The Firmware is a piece of software that is loaded to a memory chip.
Error of the software has occurred, you therefore may need to flash the firmware of the printer.
Find the Firmware on the Lexmark website, be sure to get the EXACT one for your printer.
Remember a failed attempt will render your printer useless, contact a professional to flash the fimware if you are unsure.
Thanking you
damnor01
Apr 14, 2011 | Lexmark X544dn All-In-One Laser Printer
HP Scanjet 3300C I donot seemto beable to scan with the above. Whenever I select "Start New scan " I get the following " an undefined error has occurred (2117). When I close the programme...
  1. Unplug printer from usb
  2. remove printer from installed printers in windows, chose delete all files when asked.
  3. Reinstall printer software from disk
  4. connect printer back to computer usb
Jul 24, 2008 | HP Office Equipment & Supplies
Looking for some one to work on a gestetner a045 in louisville ky
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 06, 2011 | Gestetner A045 Wide Format Copier
Error code 3825
Answer: Answer last updated:11-17-08 Error code resolutions are updated on a regular basis. If, after you search, you cannot find a resolution to your error, the instructions below can help you.
IMPORTANT: Print this page before continuing.
Search for a resolution to your specific error code:
  1. Go to KODAK EASYSHARE Software Support.
  2. In the box under Find Answers, type the complete error code (without spaces), then click Search. An example is 12x413x1304x
If you don't find information for your specific error, follow the instructions below:
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
Nov 03, 2010 | Office Equipment & Supplies
What does coms error 00E8 mean?
Canon FAXPHONE L120 Laser Printer Please follow the instruction as given below may this will help u any
Error Codes
An error code is a four-digit code displayed on the LCD or in the bottom row of a TX Result Report or an RX Result Report when an error occurs.
See the table below for individual error codes.
Error Code Description Action 0001 The sender may not be using a G3 fax machine. Make sure the sender's machine is compatible with your machine 0070 Reception was manually canceled on the machine. Ask the sender to resend the document if necessary. 0071 The machine's memory is full. Print, send, or delete any documents stored in memory. 0080 The recipient's machine did not respond within 35 seconds. Resend the document. Ask the other party to check their machine. If you are making an overseas call, add a pause to the number. 008D The recipient's machine has run out of paper. Ask the recipient to make sure that paper is loaded in their machine. 00A0 Transmission was manually canceled on the machine. Resend the document if necessary. 00A1 There is a document jam. Clear the document jam. 00FF All redialing attempts have failed. Check if the recipient's number is correct or the telephone cable is properly connected, and try again.
Aug 18, 2010 | Canon L120 Fax Laser Printer
EXITING TALLY!! Internal Error. Contact Tally
My tally 5.4 not open when to try open tally when see exiting tally! file not found. Please give the solution immediately
Apr 27, 2010 | Tally T2245 Matrix Printer
Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Mar 03, 2010 | HP Photosmart Premium C309A All-In-One...
ERROR IS (MEMORY ACCESS VOILATION C0000005)
I AM FACING LOT OF PROBLEM DUE TO ABOVE SAID ERROR ALL THE OTHER SOFTWARE IS RUNNING PROPERLY EXECPT TALLY 7.2
TALLY IS OPEN UPTO SELECTION OF COMPANY AFTER THE COMPANY SELECTION AT GATEWAY OF TALLY IT SHOWS THE ERROR MEMORY ACCESS VOILATION C0000005
Nov 12, 2008 | Tally Line Matrix T6050 Printer
482 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
