Question about Samsung RSG307AARS Stainless Steel Side by Side Refrigerator
My refrigerator rsg307 says on screen 0f 0f. what does that mean?
Of Of means it is in demo mode
Push energy saver and freezer button at the same time for 3 seconds....
Posted on Oct 10, 2013
Samsung rs267tdrs panel displays 0F for both fridge and freezer
Here's a link to answer what the OF meaning is for your refrigerator.
Error Codes Messages Blinking
Jul 26, 2016 | Samsung Refrigerators
The screen on my ice maker/water says 0F on both the refrigerator and freezer.
The first question I have is the length of spent unplugged. I would keep it unplugged for at least 15 minutes to allow all the capacitors to discharge. I'll keep thinking, just let me know if the above works.
Sep 28, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Can't set the temp it blinks 0
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
Feb 04, 2013 | Refrigerators
What does code 0F mean? Freezer and Frig both quit working, can you help?
Sounds like it is in display mode. It will go into display mode by pressing the lighting and freezer buttons for 3 seconds. Hold both down for another 3-5 seconds and it will start cooling.
Dec 21, 2011 | Samsung RS267TD
On our Samsung RS267 and 25.5 cu ft refrigerator, we have an "OF" light on both temperature readouts (freezer and refrig.). What does this mean and how can the problem be rectify so that we will...
here is a video explaining (for all models) what is to do ..
http://www.samsung.com/us/support/owners/topic/RSG257AARS/XAA
Aug 15, 2011 | Refrigerators
There is a 0f display on my samsung refrigerator for my refrigerator and freezer temperature setting
You need to press Energy Saver and Freezer at the same time and hold for up to eight seconds. If you hear a chime when you first press the buttons, you have hit one button before the other. When you hit both at the same time, there is no chime. When the fridge exits Demo mode, the screen will go blank. Release the buttons and you will hear the compressor start.
Jan 01, 2011 | Refrigerators
Freezer is cold 0F and frige is warm 70F
cleaned it and door was open for a while. closed door and and an hour later alarm went off. alarm now flashing and alarm light still on. temperature now at 53. freezer 33
Feb 01, 2010 | Maytag MFI2568AE Side by Side French Door...
Magic Chef MCBR415S cabinet get's very HOT!
* Is your compressor motor running all the time ?
* have you checked and cleaned your condenser coils at the back ?
* Is there sufficient airflow around your refrigerator (especially at the back) ?
* Is your refrigerator and freezer cooling properly ?
Sounds like your unit is working overtime - it will usually get hot like that when compressor motor has been running a long time and heat does not dissipate properly at the back - it also gets hot after a defrost cycle - it should NOT be hot at all times. CHeck to make sure your temps are correct to rule out a stuck defrost cycle timer - your refrigerator should not be hotter than 40F and your freezer's temp between 0F-10F, the optimal temp is 0F.
Aug 17, 2009 | Magic Chef Refrigerators
Samsung RSG307AARS Stainless Steel Side by Side Refrigerator Logo
476 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
