Question about Sony BRAVIA KDL-40EX400 40" LCD TV
My sony bravia t.v keeps freezing - Sony BRAVIA KDL-40EX400 40" LCD TV
My sony bravia tv keeps shutting off
in this case you tv main board is defective because this is a temperate error please replace main board
Feb 28, 2015 | Sony Bravia Kdl - 46Hx800 46 inch 3D Led...
Cant see the"picture freeze"on sony bravia remote.
Look on Facebook I Have a Defective SONY TV.
Aug 26, 2011 | Sony Televison & Video
Keep getting content error when trying to stream netflix to bravia - what's the deal
download the latest software update for the tv. you can get the software update through esupport.sony.com
Oct 09, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Nov 30, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My sony flatscreen-bravia
If you can bring up the TV menu, it's probably the video board. If the won't come up, it could be the LVDS cable or the LCD panel. Either way I recommend a qualified service tech take care of this.
May 01, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia
sony 40" bravia keeps turning off and red stand-by light will flash. just got please help me fix this problem
Jan 28, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40EX400 40" LCD TV Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
