Question about Kenwood KAC-8104D Car Audio Amplifier
Amp turns off after about 5-10 minutes of use for a few seconds
My amp is brand new i hooked it up right and it makes my speakers pound. But the amp shuts off after only a mere 10 minutes of use for a few seconds then turns back on and works for a few more minutes then turns off again.
  • 102 Answers
One of two things...Amp is going into overload protection (should be indicated by a light on the amp), or you have insufficient power going to the amp....if this is the problem, try a 2 farad capacitor on the input power line to the amp.
Posted on Mar 12, 2009
I have a 1989 oldmosbil cutlass ciera and i upgraded to a new pioneer radio and it keeps saying amp error after a few moments of playing . What do i do
This is referring to the internal amp. Make sure none of the speaker wires are touching each other or metal. if the only speakers hooked up are the 6x9's then one or both of them probably has a bad voicecoil and is shorting out causing the radio to protect itself. Replace the 6x9's and you should be okay.
Jan 14, 2014 | Clarion DXZ438R CD Player
Why does my amp keep cutting off after a few minutes
Either amp overheating
Speakers wire are dropping below 2 ohms
Too small of wire feeding amp
Make sure amp has plenty of open space
Make sure wire feeding amp is sufficient for the wattage
Are you running the amp bridged or do you have multiple speakers hooked.
If you got anymore information I can answer a little better.
Sep 02, 2013 | Volfenhag Car Audio & Video
The problem with my marshall ma100h amp is that out of the box brand new it stopped working within a few days. Earlier I turned on the amp power switch and let it warm up. About a minute later I kicked on...
Brand new? Take it for warranty repair IMMEDIATELY... don't mess with it !!!
The only thing for you to check is that you did not turn on "STANDBY" as this shuts down the power amp and the capacitors will bleed off and sound will fade. Try switch in both states before complaining
ONLY use the amp in STANDBY for a brief period (20 seconds) to let the tubes warm up... Leaving in STANDBY for a long period straains the input filter capacitor. If you are done with using the amp, turn it off...
Jan 14, 2011 | Marshall Amplification Marshall MA100H and...
I have a brand new soundstream xxx 6500d amplifier and when i installed it for the first time protect mode light come on even without rca jacks and speaker wires hooked up. any1 can help?
You need to plug in the RCA and speakers you could blow the amp. The amp is sensing no Input and No output. I would unplug the amp wait around 30 seconds then install the rca and speakers THEN install amp to battery + cable. You should be ok.
Jan 24, 2010 | Soundstream Xxx-6500d Power Amplifier Xxx...
Amp for 12" Alpine Type R DVC 4ohm
i actually have 2 12" type s's and i did the same thing just wanted a cheap amp... i went on ebay and bought a pyramid 1600 super blue series amp..... its 1600 watts and ive also hooked it up to type r's and it POUNDS!!! ill copy and paste the website where i got mine from on ebay... if you tune it right it'll make it so you cant breathe inside your car......http://cgi.ebay.com/NEW-1600-WATT-PYRAMID-PB559X-Car-Audio-Amp-Amplifier_W0QQitemZ350169009069QQcmdZViewItemQQptZCar_Amplifiers?hash=item5187b30bad
Nov 11, 2009 | Alpine Car Audio & Video
2 car subwoofers, one doesnt play
Short in amp ? try swiching wire's to speaker's around . if other speaker then work's , speaker's are both fine . if not , then short in amp , or blown channel in amp . get new one or find someone who know's more than i do about amp's
May 24, 2009 | Kicker CVR12 Car Subwoofer
Sony xm1652z amp problems
it sounds like you have the high lvl inputs on the amp hooked up instead of the rca's. this will cause the boominess for a few seconds when the amp is on and right when you turn it off
Jul 11, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Car audio amp or speakers bad?
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
There is an inherent problem with band passes. The naturally filter out high frequencies like a crossover, including distortion, so it makes it hard to hear when the subs begin to protest.
Nov 22, 2007 | Dual XAF-460 Car Audio Amplifier
Sony XM-DS1300 amp
If they have bridged the outputs of the amp, be sure that the "ohms" load is 8 ohms. This would then apply a 4 ohm load to each of the output channels. It sounds like they have bridged the output or else hooked up the speakers in a paralled configuration that is trying to kill your amp. If you are using dual voice coil speakers then you have to treat each of the voice coils as a seperate 4 ohm speaker and wire accordingly. You need to correct this NOW or else you will fry your amp. Good luck.
Mar 03, 2007 | Sony XM-DS1300P5 Car Audio Amplifier
Kenwood KAC-8104D Car Audio Amplifier Logo
285 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
