Question about Dual Slide Controller 13398-c2 Motor Synchronous Velocity Ids Inc
One side of slider will move. How do I fix this ?
When I press switch to slide out closet,only one slide will start moving. The fault indicator says hall sig not present. Does that mean the motor is out for that side ? Or is it something I could fix myself. We are going camping this week.
Fix memory error message on camera
Hi there! Make sure the SD card is not locked. There is a tiny slider on the side. If is in the "down" position, the card cannot have new files saved to it. Move the slide to the "up" position, then reinsert the card.
If the slider is very loose, it's possible that inserting it into the camera slides it down, essentially making it useless. I have one like that. You could try a touch of superglue to make the slider harder to move, but I have never tried this and you would need to be very careful not to use too much, and to make sure it's entirely dry before putting it in your camera. Perhaps try a different memory card?
Nov 04, 2014 | DXG 518 5 Megapixel Compact Camera -...
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
The slide lock on the lock screen fliped to the right side and i want it back on the left side how do i do that?
To flip the slider to the other side you just have to press on the slider and hold it down for a couple of seconds.
It should now when you move your finger, flip from right to left.
Let go when it is the right way around for you. :)
Feb 24, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My camera indicates CARD LOCKED. How do I fix it?...
Move the slide switch on the side of the card.
May 21, 2010 | Cameras
Top right slider button won't slide to "picture" will only take pictures, and won't take videos also, the right side faceplate came off because both screws fell out.
This is a very easy fix, Recommend first calling 1-800-OK-CANON to get an estimate for their repair. It really should not be costly at all to repair due to the ease of the repair.
But, if they seem unreasonable in their estimate, you'll need to move the back face plate backward just enough so that you can align the slide button with its inner switch. Just remove the screws (keeping track of where they go) along the perimeter of the back faceplate. Using your fingers only, gently pry the plate back a small amount sufficient enough that you can move the switch to its other position. Reseat the back and see if the switch moves freely. Then try out the camera, and reseat the screws.
If you don't feel comfortable doing the above, find a friend who is.
Jan 15, 2010 | Canon PowerShot SD790 IS Digital Camera
How do I life up the screen (open the laptop) on an HP Pavilion vd 4000? when I press the central button on the front, nothing happens.
When you push on the center button, that is supposed to move two hold down teeth to the side allowing the screen to move up. You then grab the lid and lift the screen manually into position. If the lid will not move up with the button depressed, then a piece of linkage is either binding or broken. In that case, keep the button depressed and try taking a credit card and sliding it from one side to the other and then back in the opposite direction, the teeth are tied together so if you move one, you move both. If you feel resistance on the card, try lifting the lid as you move the teeth.
Sep 27, 2009 | Computers & Internet
How to remove an ignition switch on an 1991 caprice
See Figure 1
0900c15280047a11.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Ignition switch assembly
If equipped with an air bag system, make certain to follow the recommended disarming procedure before, and rearming procedure after, repairs.
  1. Disconnect the negative battery cable and disable the air bag system, if equipped.
  2. Remove the column to instrument panel trim plates and attaching nuts.
  3. Lower the steering column and disconnect the shift indicator cable.
  4. Disconnect the ignition and dimmer switch wire connectors.
The steering column must be supported at all times to prevent damage.
  1. Remove the switch attaching screws and remove the dimmer switch followed by the ignition switch.
To install:
  1. Move the key lock to the LOCK position.
  2. Move the actuator rod hole in the switch to the LOCK position.
  3. Install the switch with the rod in the hole. Adjust the ignition switch as follows:
    1. 1990 - Place a 3/32 inch drill bit in the hole on the switch to lock the switch into position. Move the switch slider to the extreme left position then move the slider 1 detent to the right OFF LOCK position. Remove the drill bit.
    2. 1991-93 - Install the ignition switch in the LOCK position. Move the switch slider to the extreme right position and move the slider 1 detent to the left LOCK position. Depress switch mechanism slightly to insert a 3/32 inch drill bit into ignition switch.
  4. Position and reassemble the steering column in reverse of the disassembly following the proper coil centering procedure. Enable the air bag system, if equipped, as follows:
    1. Connect the yellow 2-way SIR harness connector located at the base of the steering column.
    2. Install the SIR fuse to the fuse block.
    3. Turn the ignition switch to RUN and verify the inflatable restraint indicator flashes 7-9 times and then turns off.
Jul 29, 2009 | 1991 Chevrolet Caprice
Bottom Draw Wont Close
Check the sides of the drawer on the dishwasher and make sure that the sliders that the drawer rides on are not locked in place you will notice on the front of the slider near the door panel there are plastic clip like press in tabs that hold the drawer securely in the tracks try to put your hand up under the door and move the track if the track moves in the slider you will need to hold the door secuely with one hand while sliding the track to the most open position on the slider track. if the sliders are not locked in you will be able to pull the slider forward and the slider should clip into place.Repeat this for both sides and the door should operate like new once again.
Jan 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My hp m22 won't turn on
Read 'nightdivers' earlier answer The problem is that there is a small, less than 1 cm rectangular magnet, embedded in the slide cover just to the right side of the "HP" logo and above the "M22" marking, the magnet activates a metallic reed switch on the circuit board when the slide is move to the right to "turn on" the camera and take pictures also exposing the lens. When the slide is moved to the left, the reed switch contacts are off. This would be an easy fix for a camera shop (as long as you tell them what the problem is) and they would not be able to overcharge you with the knowledge you now have... This is a great camera, and would be well worth the fix My addition is: I used a magnetic ended screwdriver and lightly tapped the magnet end over where the badge/logo covers when the slider is opened. hey presto, my camera sprang back into life!
Dec 25, 2006 | HP Photosmart M22 Digital Camera
Hp photosmart m22 wont even turn on dont no why or how to fix
Read 'nightdivers' earlier answer The problem is that there is a small, less than 1 cm rectangular magnet, embedded in the slide cover just to the right side of the "HP" logo and above the "M22" marking, the magnet activates a metallic reed switch on the circuit board when the slide is move to the right to "turn on" the camera and take pictures also exposing the lens. When the slide is moved to the left, the reed switch contacts are off. This would be an easy fix for a camera shop (as long as you tell them what the problem is) and they would not be able to overcharge you with the knowledge you now have... This is a great camera, and would be well worth the fix My addition is: I used a magnetic ended screwdriver and lightly tapped the magnet end over where the badge/logo covers when the slider is opened. hey presto, my camera sprang back into life! reed switch must have just stuck
Dec 19, 2006 | HP Photosmart M22 Digital Camera
Dual Slide Controller 13398-c2 Motor Synchronous Velocity Ids Inc Logo
179 people viewed this question
Top Dual Video Game Consoles & Games Experts
James Wishart
Are you a Dual Video Game Console and Game Expert? Answer questions, earn points and help others
