Question about Coleman Heating & Cooling
RV Airconditioner capacitor overload blew up.
While camping this weekend, my Coleman RV AC unit capacitor overload blew up. The white wire was melted also. The ac unit is 2 years old and had been working fine. It was off when this occurred. Last time used was about 30 hours prior. The motor home is a 1984 with original breaker box and wiring. Any help as to why this occurred?
    Guru:
  • 588 Answers
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Posted on Apr 05, 2016
koolbreezes
  • 540 Answers
SOURCE: Goodman CKL60-1 Condenser Fan Runs OK, then stops
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Posted on Aug 25, 2008
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
SOURCE: Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
Posted on May 18, 2009
relaga58
  • 158 Answers
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
Posted on May 28, 2009
  • 415 Answers
SOURCE: I purchased a 60-Amp Cutler-Hammer Fusible Pullout
The two wires coming from the breaker box go to the terminals marked "LINE". The two wires going to your AC unit go to the terminals marked "LOAD".
Hope you find this to be very helpful. :-)
Posted on Mar 22, 2010
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
Camping trailor
that sounds like the problem it blew the circuit breaker,if not it might have a seperate fuse for the aircon .
Dec 22, 2013 | Cruiser RV 2013 Fun Finder X X-210
Coleman Mach RV Airconditioner ? Compressor comes on but hum isn't quite rite. The T-stat doesn't make a click when adjusted either. Kids turned it down and back up too quick n blew something or is...
under the shroud there is a circuit board it has a fuse on it called F-1 this fuse starts the compressor through the thermostat.
the sound you are mistaking for the compressor is the AC fan
yes you can jump the thermostat as it only has 12 volts on the wires
if you start capacitor was bad it would be buldged on the top of it's can and, probably leaking electrolyte
Sep 05, 2013 | Heating & Cooling
My air cond is blowing the 20 amp breaker when camping but runs just fine for the dealer. It blew 11 times in 48 hours last weekend.
Ifr you are plugging into a external source for power, they or whereever you are camping has the wiring issues, to small of wire
Jun 17, 2010 | Dometic Rooftop RV Air Conditioner
Easy Start Capacitor
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Feb 21, 2010 | Dometic Rooftop RV Air Conditioner
Compressor will not run
It sounds like tha capacitor is shot. You'll need to have it replaced.
Best regards, --W/D--
Aug 08, 2009 | Dometic Rooftop RV Air Conditioner
We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Coleman mach wire schematics?
GO TO
www.rvcomfort.com
Aug 04, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
