Question about Troy Bilt Tb70ss Gas Trimmer
Engine won't start - Troy Bilt Tb70ss Gas Trimmer
  • Troy Master
  • 7,482 Answers
Hi resqdiver15...
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
2008 Lexus ES350 won't start after multiple times
You will need the dealer to look at his, diagnosis of this problem takes special equipment and skills.
Oct 22, 2012 | Cars & Trucks
2003 lexus es300 won't start... radio lights and windows work. Tried a jump start, still doesnt work...
Are you saying the engine cranks but won't start, or the engine won't crank ?
If the engine does not crank, you would check for voltage at the starter, the neutral safety switch, and the key switch as well as the ground connections.
Sep 18, 2012 | 2003 Lexus ES 300
Engine won't start getting fuel and fire crank but won't start it wants to backfire
Try posting this question under mowers. This is the measurement tools category.
Aug 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I changed the oil in my 98 concorde and now it wont start. The oil light is on but not the check engine light.\
do you here the fuel pump working when you turn the key?If not could be a fuse that runs the fuel pump.
Aug 05, 2012 | 1998 Chrysler Concorde
Cranks, but won't start
Could be the crank sensor is bad but If the check engine light does NOT come on when cranking at the times when it won't start, then your ECU is in need of repair. The engine will only start after the check engine light comes on and the ecu is what controls that. It's likely going bad, causing the delayed start problem typical of early 90's jeeps. Repair or replacement services for your jeep ECU are available on ebay.
Aug 01, 2012 | 1995 Jeep Grand Cherokee
Won't start lights come on but engine won't do anything
There is a good chance that you have a blown fuse or that your starter is gone.
May 16, 2012 | 2004 Chevrolet Express
2003 Landrover Freelander SE V6 == Service Engine Soon (not Check Engine) light has been infrequently flickering on/off for the past 8 weeks. While light is on, engine hesitates slightly.Vehicle would not...
If it won't start have a compression test done and see if one bank doesn't have compression . The intake cam is known for breaking at the front lobe
Nov 09, 2011 | 2002 Land Rover Freelander
Replace starter and battery 1999 Mazda 626 still won't start
Won't start or engine won't turn over and try to start?
Aug 06, 2011 | 1999 Mazda 626
Troy Bilt Tb70ss Gas Trimmer Logo
32 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
