Question about Car Audio & Video
Club car 48 volt electric motor wire diagram - Car Audio & Video
voodoomox
  • 1689 Answers
SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Posted on Jul 24, 2008
weblord
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
BlackHand-En
  • 68 Answers
SOURCE: 2005 Club Car brake lights
check the fuses of the brake light...
and also check if the bulb is working or not..
Posted on Jan 28, 2009
james3751
  • 614 Answers
SOURCE: i have a dayton 1 1/2 h.p electric motor, and need
Line is L1 L2 L3 to line voltage. wire nut 4-7 together wirenut 5-7 together and wirenut 6-9 together connect 123 to line for low voltage 123 together 456 together 679 together. This works on all dual voltage 3 phase motors. Some of the newer Daytom motors have a plug that you just turn for changing voltage. Rudty
Posted on Jun 07, 2009
SOURCE: wiring diagram for electric motor
The more I look at this motor the more I think that it is a stepping motor and not an AC motor... I could be wrong, but checking the windings and seeing the small Tach Motor on the rear leads me to believe that this is not a ac motor, but a stepping motor and is triggered from the programmer for rpm
Posted on Apr 16, 2010
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
48 volt club car 4 12 v batteries one batterie checks 20 v when I single it out when I unhook it it checks 12 v
If you have 4 off 12 volt batteries connected in series (positive to negative leaving a positive terminal and negative terminal with no wires on then that is 48 volts. To check the batteries you have to disconnect each battery and have a load test done on each battery for 12 volts and dead cells. To get 20 volts you still have 2 batteries connected together with a good battery connected to a battery with a dead cell or else you would have 24 volts.
Oct 03, 2013 | Cars & Trucks
1998 48V electric club car - just replaced 48 volt batteries and two solenoids, but still can't get it to run. can hear back up alarm, but no juice to key switch or pedal. help!
If you go to www.studmonkeyracing.com/forums/cc48v.jpg you will find a schematic for what I believe will be close to wiring of your cart. A systematic check of volts to the various components should get you going. 1st port of call, you should see 48 volts on both sides of the keyswitch when it is on. Check the fuse in line with the red wire from the solenoid to the on-board computer.
It may simply be that you have one battery terminal too loose and it just wont allow you to draw enough current to run anything but the buzzer. Does the buzzer stop when you press your foot on the gas? If so it really does point to a loose battery connection.
Jun 10, 2011 | 3d Rose Londons Times Funny Cow Cartoons -...
Club car golf cart will only travel 3 ft. then cuts off.
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Nov 20, 2008 | Golf
Wiring diagram
good luck
Wiring diagram
Jul 24, 2008 | Car Audio & Video
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
