Question about Kodak Hero 9.1 Wireless All-in-One Printer/Copier/Fax Machine/Scanner
Forgot admin password
I was trying to set up scan on my printer and it asked for my admin password
I forgot admin password
To reset the SWS (SyncThru Web Service) password:
  1. Press the Menu button.
  2. Press the right or left arrow until Network appears, then press OK.
  3. Press the right or left arrow until Clear Settings appears, then press OK.
  4. Select Yes and press OK.
  5. After the printer finishes clearing the network settings, unplug it for a few seconds then plug it in again.
  6. All network settings (including the SWS password) will be reset. If you had manually configured IP info or were connected to a wireless network, you will need to re-enter those settings now.
  7. The login will default back to admin and the password will be sec00000.
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Dec 17, 2012 | Samsung SCX-6345N Printer
Default admin password? I didn't set an admin password, what is the default admin password?
Is the installation software being installed on an account with administrator privileges? If not, log off and log back on with an account that has admin privileges. If your account has admin privileges, and the install asks for the password, and you know you have not set such a password, pressing the enter key may skip this problem.
Dec 03, 2009 | Canon PIXMA MP620 All-In-One InkJet...
How do I create/set up the IP address for a toshiba estudio 353 copy/fax/scan unit?
On control panel press "user functions" , then select admin tab, press password and type password (default is 123456),press network and then ipv4. There you need to type in free IP address, subnet mask and gateway.
For more ask your network admin.
Oct 13, 2009 | Toshiba e-Studio 282 Printer
Ask for password
linksys always has a default password.
admin
admin
If you changed it you can reset it by holding down the reset in the back and unpluging it.
Jun 09, 2009 | Linksys WPSM54G Print Server
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
May 20, 2009 | Copystar CS-2550 All-In-One Printer
I have a Toshiba studio 281c, we forgot the ADMIN password, help!
the default password should be "123456".
If u did changed the default password, then u need to enter setting mode 08 - 263 to check or edit the password.
Mar 10, 2009 | Toshiba E-STUDIO 450 Copier
New laptop want to connect but forgot key
what you want exactly?password for what? username and password for internet in subscriber? or just WEP for wireless key password?
if you forgot the password for username and password for subscriber....theres an option,i dont know what kind of subscriber do you have in your country...if you forgot the username and passowrd you can ask in the subscriber.
regarding in the WEP password for wireless,it doesnt matter,try this..
type 192.168.1.1 in the internet toolbar
username:admin
password:admin
and you can see the configuration,check the wireless settings for WEP...
Jan 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Kodak Hero 9.1 Wireless All-in-One Printer/Copier/Fax Machine/Scanner Logo
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
