Question about Panasonic DMR-EH68 1080p PAL/NTSC Code Free DVD Recorder
Dmr-eh68 to read region 4
I want to open region 2 to read region 4
IB4G2008
  • 3587 Answers
SOURCE: Unlocking the region code (code2) on a Panasonic DMR E85H to use region 4 DVD's.
hmmm..ok..do you have user manual, or do you need one?
Posted on Mar 11, 2008
  • 280 Answers
SOURCE: Panasonic dmr-ex88 won't play any dvd, or music
If you are in the U.S. try region 1.
other wise the unit may need a firmware update
Posted on Jun 19, 2009
bob_computer
  • 3153 Answers
SOURCE: how do I change to region code for a DMR EH59 from
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to
try here
or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Posted on Oct 04, 2009
Obertelli
  • 3006 Answers
SOURCE: My panasonic dmr-ea18 says it supports Region 1.
Easy answer. You don't.
Like many Sony and Panasonic models there is no hack possible on this model as the region coding is specific to the internal hardware.
The only way to do it is with a new main board and that will cost far more than a cheap and easily hackable player such as the excellent Philips DVP5980 with progressive scan, USB input, DivX and HDMI upscaling, still widely available at clearance outlets for under £30.
Sorry to disappoint you but hopefully I've saved you wasting time on further searches.
Posted on Dec 12, 2009
  • 1044 Answers
SOURCE: Playing DVDs
NoThese days most of the companies are producing Region 0/ALL DVDs If you can get them OR buy a dual region DVD i.e. Region 2/4 which can play on both the regions. Most of the DVDs produced in India are multiregions. Choice is yours now
Posted on Apr 17, 2010
Testimonial: "This confirmed what I suspected, so to an technology phobic mature person it was helpful to have this confirmed. Thanks."
Dvd3 remote dvd1 mode
make this steps and fix it. Merry Christmas
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Dec 16, 2013 | Panasonic DMR-ES10 DVD Recorder
My panasonic dmr ex77 is not multi region. How can i make it so?
The procedure below is a hack , can interfere with the normal working of the DVD player
*** Please note *** You will need a laptop with an Infrared (IR) port to use this method.
Most modern laptops have now dispensed with IR ports in favour of WiFi and Bluetooth, so you may need to forage around and find an older laptop with IR.
1) Download both parts of Chachi's RAR file (both of these files can be easily found on this forum).
You will need both files, as the ISO image file has been split across two compressed files.
2) Using WinRAR or WinZip unpack the ISO image file to a folder on your hard disk (the desktop is a good place, so you can easily find it later).
To successfully unpack the ISO image file, both of Chachi's RAR files must reside in the same folder.
As you extract the ISO file from the first archive, WinRAR or WinZip will automatically move to the second file and continue the unpacking process.
After the unpacking process has completed you will be left with a single file with the extension ISO.
3) Using Nero (or similar), use the "Burn Image to Disk" feature to burn the ISO CD image onto a blank CD (just copying the ISO image file onto a CD will not work).
I used Nero to achieve this, but most CD burning software can do the same.
4) On the laptop, ensure that the IR port is set to COM2 in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
Try to select an older IR mode if available.
My old Toshiba Satellite 4030CDT only supported FAST IR modes and wouldn't work.
I then switched to an Acer Aspire 2000 and through trial and error found the "IrDA (HPSIR)" mode worked perfectly.
5) Boot the laptop from the CD
If your laptop does not give you the option to change the boot drive order at POST, you may need to temporarily change your boot drive order in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
6) When the laptop has sucessfully booted from the CD you will be presented with a menu.
Using the down cursor key, select option "4. Minimal Boot" and press return.
7) At the "A:\>" prompt type "cd winamp" and press return.
8) At the next prompt "A:\>WINAMP\" type "winsamp" and press return.
9) The Remote control test tool should now be loaded (blue screen with white text).
10) Press the "r" key to load in the REMOTE.TXT file (this file contains the IR signal information required to reprogram your DMR-EX77).
11) The captions "button 1" to "button 10" near the bottom of the screen will now have changed from white to pink.
These are the emulated buttons you will need to press in order to unlock you unit.
Ensure "button 1" is highlighted before proceeding to the next step.
12) Power on your DMR-EX77 and switch it to DVD mode.
You must ensure the disk tray is empty during this process.
I had my disk tray empty and ejected (sticking out) during the process just as a precaution.
13) Point the IR port on your laptop at the IR receiver on your DMR-EX77.
The IR port on the DMR-EX77 is located just above the DVD/CD Open/Close button on the right of the unit.
I found the optimum distance between the laptop and the infrared receiver on the DMR-EX77 was approximately 5~6 centimetres, any more and it may not work.
14) With the IR ports aligned and "button 1" highlighted in pink press the return key on the laptop, wait a moment, cursor right to "button 2" and press the return key, wait a moment, cursor right to "button 3" etc....
Keep repeating this procedure until you have entered all buttons highlighted in pink from 1 to 10 in order.
If your DMR-EX77 reacts as mine did during the process you may see the display on the DMR-EX77 change and also experience the TV channel changing.
Don't panic as this appears to be quite normal during the unlocking process.
15) If all has gone well the display on the DMR-EX77 should now read "HELLO" and you should hear the hard disk spin down for a second, then spin up again.
The DMR-EX77 has new reset itself and has successfully been reprogrammed.
Leave the unit alone for approximately 10~15 seconds before doing anything else, just to be on the safe side.
16) The buttons on the front of the DMR-EX77 unit will no longer function, so switch the DMR-EX77 off using the remote control.
If you left the tray poking out during the reprogramming process (as I did), just wait a few seconds and it will close automatically, you can then switch off the DMR-EX77 using the remote.
There is no need to disconnect the DMR-EX77 from the mains supply.
17) Switch the unit back on, pop in any region DVD you like, sit back and enjoy biggrin.gif
Switch off your DMR-EX77 using the power button and leave it off for a few seconds.
Switch back on your DMR-EX77 and when it's ready try the proceedure again.
I failed several times initially, but it didn't seem to do any harm and everything is fine.
You may also find that changing the IR mode setting in your laptops BIOS may help.
I had to try a few different modes until I found one that worked.
If you can't find the files you need, or require the procedure for using another type of device to region free your DMR-EX77, then visit:
http://www.dcevolution.net/panasonic...tpage&Itemid=1 user_offline.gif
Apr 22, 2008 | Televison & Video
How to play region 1 dvd's on dmr-ez27
http://service.us.panasonic.com/OPERMANPDF/DMREZ27-MUL.pdf
this plays region 1 or all regions disc.....recording format can be different, may not play some discs...read this.......good success, meder's tv service
Nov 28, 2012 | Panasonic DMREZ27 DVD Recorder
Playing DVDs
Apr 17, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Change from region 4 to multi region
http://www.videohelp.com/dvdhacks?dvdplayer=DMR-ES25&hits=50&Search=Search
http://www.dcevolution.net/panasonic/index.php?option=com_content&task=view&id=32&Itemid=54
I made my Panasonic DMR-ES25 Player/Recorder Multi Region successfully by following the instructions "Sending the IR code with a PocketPC" from this site:
May 24, 2009 | Panasonic DMR-ES25 DVD Recorder
Unlocking region code panasonic dmr-ex77 dmr-ex87
I have a panasonic dvd recorder. Model dmr-ex87
I was going through the options for the remote control and i selected dvd 3..Well this has caused problems as the remote only displays dvd3 when you press any buttons on the remote. How can i get it back on dvd1??
Apr 16, 2008 | Televison & Video
My record change from DMR-E55PL-S (South America model) to DMR-E55P (USA model)
Hi
You can get a special remote controller that has a built in hack that will turn your DMR E55 into a multi region player. In the UK these are available to hire from the following website. You do not need to open your unit, just press a few buttons on the controller.
http://www.multiregionupgrades.co.uk/upgrades/mods/pandiy.htm
Follow the instructions exactly to the letter.
Please note, if you have purchased a new DMR E55, this upgrade may invalidate your guarantee.
Hope this helps
Oct 07, 2006 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-EH68 1080p PAL/NTSC Code Free DVD Recorder Logo
16 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
