Outside compressor connecter does not connect
I have 2 exact ac & electric heat units. Transformer went out on one had a ac company???? come out he changed the transformer and when he left the heat came on when the air should and etc everything wrong. I looked at my other unit how it was wired and changed the wiring they done back to how my other uit was wired and everything works fine now except outside compressor does not come on when stat calls for it. New compressor connector new transformer.
  • 56 Answers
SOURCE: Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Posted on Feb 16, 2009
farfield
  • 462 Answers
SOURCE: burning up transformers
YOUR the first person that has gave enough information to help in a WHILE THANK YOU SO MUCH!!
Start all over from first
I'm betting that you need a fuse in both sides of the transformer until you find the real reason they burn up.
A solenoid valve that sticks can cause the transformer to blow but so can a lot of other things, namely anything in the control circuit that uses the 24V power. A relay or contactor that doesn't pull in or a defective defrost control, a shorted wire from the thermostat.
I'm wondering if you have what we call a package heat pump meaning the both the indoor blower and out door compressor & fan are in the same section out side? OR is your a split system with an indoor section and an outdoor section?
I'm betting on the split section. In some miss-matched systems (like a Lennox indoor and a GMC out door for example) Some of the origonal Lennox heat pumps had an out door and an indoor transformer. If these trans formers were not "phased" together it could cause a problem like your having. Now you just have it in the heatign mode if I read between the lines correctly. So it makes snece that it's something with the heat. The out door unit can opperate withits own 24v but if you have back up heat inside (gas or electric Im thinking you have electric) the indoor section will come on atfter a few more degrees of heat loss (2-4'F). This is where the transformer inside will buck the one outside and somethjing has to give. The weakest point.
From what ive been told by some of the old hands I've been around if the high volt side burns out look for a low volt problem if the low volt burns out look for a line volt problem.
If this has 2 transformers like I suspect try the fuse on both sides but remember the one is hot and will remain hot all time on 220V or 1 leg of it or it might remind you. To phase these transfoprmers I believe you swtich the main lines L1 & L2 at either of the transformers. Now 1 more thing the indoor section may be using ground on the low volt side as a path for 1 side of the transformer. I believe you will ahve to do same for the other transformer too.
Hope this helps Id really like to know what you find and do.
Please ask more and you give such detail I can follow you with little trouble. Please rate me as high as you can and good luck.
Posted on Mar 30, 2009
  • 26 Answers
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Posted on Jul 07, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have a colman evcon split unit, I had a guy
Hi, you do have a dead short in the control side of the system. Good that you bought a transformer with the breaker. Most people don't and will smoke several of them. Anyway, it is a split system. If it was iced up, it must be a heat-pump, not gas fired. The problem will be in either the stat wiring from stat to indoor unit, to outdoor unit, and if a wire is not grounded in the stat wires, one of the 24volt controls have a dead short as the breaker trips instantly. Here is what you will need to do. You will need to do a process of elimination on all of the 24volt controls. I would start at the outdoor unit as you engaged the contactor by finger to check for power. If you see no stat wiring outside touching, the coil on the contactor is 24 volts and may be the shorted control. Coil could be bad. Pull a wire off the coil,there will be 2 wires at the sides. I am sure you know which are the low voltage controls if you can replace a transformer, this is great. You can find this pretty easy. If you pull a wire off one side and reset the unit and the breaker does not trip, then you know the low voltage coil is compromised. If it trips, go to the next low voltage control as the 24 volt coil on the rsv ( reversing valve ) and unplug it. If you have the schematic handy, it will show you all of the componants on the low voltage side/secondary side of unit that you will need to check until the breaker stops tripping. This is the best way to find the culprit!! I have done this for 33 years as a contractor and I am sure you will find this short very soon by doing this. Here is a tip for you also. Sometimes on the transformers that have these tiny resets on them, will wear out pretty fast. What you can do is take a 3 to 5 amp automotive type fuse and on the 24 volt side of the transformer you just cut the red/ hot wire/24v. and crimp a female stak-on to each end of the wire you cut. Then plug each end onto the fuse.Use some electrical tape around it so any bare metal that may be showing will not touch and blow fuse. This is a good way to protect all transformers that have no breaker if you end up with a short. Cheaper to replace a fuse then to keep replacing transformers every time! The fuse will just blow and you can start looking for the short. Now on your unit you can go to the indoor section where the transformer is that you put in. You can eliminate the thermostat and control wiring to the indoor unit and outdoor unit real fast so you know where or which section the short is in. Just kill main power, now where your stat wiring terminates you will disconnect from the control board. Since you have a heat pump you will have more control wires to work with, so either draw a diagram or use the one on your panel to reattach. Remove the wires from the board that take off to the stat first and supply power back to it. If the breaker holds, you will know the short is either the stat wiring from the indoor unit are touching somewhere/grounded or at the stat.You will then know that's where the short is as you have narrowed your search way down. If it trips, you will do the same to the control wires that go to the outdoor unit. If you disconnect it at the board and it holds, you will know it is from the wiring there to the outdoor unit! So, you either have wires grounded from there out or a low voltage control part has burned out. If you remove all of the control/thermostat wires at the board to the indoor and outdoor unit and it still trips, the short will be in the indoor unit which will more then likely be the board itself. Yes sir, this is really a very easy fix for you and I feel you have the ability to do this checks your self. The short has to be on the low voltage side of the transformer as you have proved that! You traced it right back to the transformer secondary low voltage side. So, just take your time and follow my instructions the best you can, and you will find out which part of the system the short is in and then narrow the search down further! I have a hunch the coil is burned/shorted on the contactor :) A place to start by pulling one little wire off the coil. I know this is a long explanation but I wanted you to understand and help you as much as possible on how to tackle this. Sounds difficult but it is not at all. It is either a low volt componant on the outdoor/indoor/ thermostat/ or stat wiring. If none of those, with all low voltage wires removed at board and it still trips, the board is shorted to ground. You can kill power to indoor unit and carefully take the board loose to look at the back side for any hot spots and you will know its the board. I had one totally smoked on a 5 ton package heat pump yesterday in fact!!! I could not see it until I pulled the board/defrost board out far enough to see it, but I knew it was the problem as it would not control the reversing valve, fan control, or run the condenser fan motor. Please drop me a line and let me know how you are doing, please. I would love to know that you were able to find it as I know you will. Best of luck to you.
Sincerely,
Shastalaker7
Posted on May 06, 2010
SOURCE: My dog chewed up the
Hello,Yes there is a 3 amp blade fuse(same as in a car) in the blower unit,take off the door and it is plugged in to the(curcuit) board.Pull it out and slip a new one in.That will restore the control voltage.Your repair sounds correct.Some times there is a tiny button on the transformer itself (square box) that pops up instead of a fuse just push that in to reset it(if applys).
Posted on Oct 19, 2010
Fujita 3hp split system Compressor won't start
Ohm out the compressor...if it is new & getting the correct power, should be under warranty. You should not have to install a hard start kit on a new unit.
Dec 14, 2013 | Heating & Cooling
Heat Pump Blowing Cold
Unless you just installed or had the thermostat installed recently, I would not point at the thermostat as the problem. With what you have described I would suggest have your units serviced as it sounds like a loss of charge, or failed defrost control board. The "Aux" comes on when the unit is using secondary heating (electric heat strips). That occurs when the demand temperature (what you set it to) in Heat mode is more than the current room temperature, usually ~2-4 degrees higher. Also happens in defrost mode. Defrost is a heat pump cycle that melts any build up of ice on the condenser unit (outside unit). That process is simply the unit running in cool mode which will heat up the outside unit to melt any ice. Defrost cycles vary with manufacture but usually you can tell if is in defrost by looking at the outside unit, during defrost the unit will be warm or hot sometimes there is steam and the compressor will be running but not the fan. Defrost only happens on heat pumps in "Heat" mode. Rheem has a 10 yr compressor and parts warranty, so call the installer or Rheem authorized service company.
Nov 11, 2013 | Honeywell RTH7600D Touchscreen 7-Day...
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
Goodman ac compressor freezes up 2 times past month. Ran water over it and it started again. Filters are clean and changed. This time called ac contractor and he gave it a "quick start?". Lasted...
Wash outside unit coil and make sure they are clean .also make sure the fan is running on the outside and inside unit.
If everything is working and clean then you might have a leak and low on refrigerant
Jan 29, 2018 | Goodman Heating & Cooling
BDP Heat Pump Transformer Keeps Blowing
Should have a 5 amp fuse on red wire in between transformer and tstat. If not put one. This will protect transformer. Turn power off and take a good picture of tstat wiring. Remove all wires to the tstat. With the air handler wires join fan and red. (Likely green) let run. Then add compressor and reversing valve ( if reversing valve is energized in cooling ) which in most cases it is. Should then have cold air. Let run. If no problems you know it's outside of the machine. Tstat or wiring. Hook inside of machine all back up to tstat wires. Do the same thing with the tstat wire inside the thermostat. If no problems, must be bad tstat. Hook everything back up right. If fuse blows or transformer because you didn't put the fuse, then you know for sure it's the stat. Good Luck
Mar 15, 2017 | Heating & Cooling
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
Having a problem with my AC/Furnace. AC was working fine and was turned on for about 3 weeks. Thursday night it cooled off and we opened up until Saturday morning. On Saturday morning the AC would not turn...
I think your problem is poor usage of the device,i.e. overloading the system. try running better cables to your furnace and ac. The reason i am lead to believe that is. If you already hired a pro to come and fix it for you,and he/she could'nt then what else could it be? in my experience ac units use electricity like microwave ovens.and power tools
Sep 12, 2009 | Heating & Cooling
AC Breaker trips and AC Fan turns slow.
Sounds like you have a bad capacitor for your squirrel cage fan , now as for the a/c unit sounds like you have a direct short in compressor to ground or leg to leg , check all wiring to make sure that it is not grounding out or melted together.
Jul 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Oct 01, 2008 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
