Question about Garden
Replace fuel lines on model no. 358.797931 - Garden
  • 7,482 Answers
Hi.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash, broken lines,etc. from the fuel tank.
After you have all the trash,fuel lines and filter removed.
You will trim the end that goes into the fuel tank to a point.You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers push the fuel line and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank .
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Hook up the fuel lines to the carburator and you should be good to go
Please take time to rate me
Bud
Posted on Apr 23, 2013
How much would it cost to replace a Mercedes 600 sel v12 fuel line?
I think it would be cheaper to go to NAPA,and buy fuel lines and bend them to fit,than going thru dealer
Oct 15, 2013 | Mercedes-Benz Cars & Trucks
Audi a4 1998 all engine names/parts
Check the help link related to Acura car models:---
How to Clear OBD error Codes on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list for Acura Car Models?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
Underhood components http://www.howtorepairguide.com/2012/11/lincoln-underhood-components.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace Power Steering Pump on Acura Car Models?
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to replace Steering Linkage on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
How to replace Steering Wheel on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-wheel-on-acura.html
How to replace Power Steering Pump on 1999 Acura TL? http://howtobyme.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to Test and Replace Fuel Injectors on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-fuel-injectors.html
How to replace Fuel Tank Assembly?
http://vwrepairhelp.blogspot.com/2011/11/how-to-replace-fuel-tank-assembly.html
FUEL LINES AND FITTINGS on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/fuel-lines-and-fittings-on-acura-car.html
Replacing Fuel Charging Assembly on Car?
http://vwrepairhelp.blogspot.com/2011/11/replacing-fuel-charging-assembly-on-car.html
Intermittent Charging Problem with Engine warning Light?
http://whoisbyme.blogspot.in/2012/07/intermittent-charging-problem-with.html
How to replace Fuel Pressure Regulator on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-fuel-pressure-regulator.html
How to test Fuel Pressure and replace Fuel Pump on Acura Car models? http://repairhelpcenter.blogspot.com/2011/11/how-to-test-fuel-pressure-and-replace.html
These will help.
Thanks.
Nov 22, 2012 | 2004 Audi A4
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
FUEL FILTER
(For 40/55/60/70/110/115/155/165 Models
Only)
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Gas leaking from grommet that goes into the gas tank.model pb-2111.
replace grommet. you may want to replace the fuel lines to you can use echo part number # 90098. its a fuel line kit and it come with all fuel lines, grommet, fuel filter, and vent. its plug and play.
Sep 21, 2011 | Echo Garden
I have a Husqvarna model 444 chain saw. The fuel pick up line disolved in the fuel tank. How do I replace?
order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Aug 25, 2010 | Husqvarna Chain Saw 20" Bar
My McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Oct 13, 2009 | Garden
How to replace fuel lines on Jonsered trimmer model GT 21L
if it's electric, it shouldn't have a carby. Fuel lines are quite simple to replace. try your dealer or someone who does mowers and chainsaws.
Oct 02, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
1,512 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
