Question about Kwikset Locks & Locksmithing
There is a tubular "Lazy cam" or tailpiece that passes from the cylinder on the outside operated with a key through the bolt and into the thumb turn on the inside. There is as "E" clip that holds the tubular Cylinder bar or "tailpiece" in place. Fixing it to the back of the keyed cylinder. The center portion of the clip ( that differentiates it from a "c" clip ) passes through a slot in the Cylinder bar to limit its "free rotation" this allows the tailpiece to turn freely enough for the thumb turn to operate the bolt from the inside without binding against the keyed cylinder on the outside, from the outside when you rotate the key far enough in either direction the clip comes to the end of the slot, catches and rotates the bar to operate the bolt. your problem is a broken clip. It is very common, and has been a vulnerability with this design for decades. The cause is usually tension on the bolt during operation with the key ( bolt dragging or rubbing against the strike on the frame) . You can replace the clip and relocate the strike plates on the frame to avoid this again or purchase something a little better than Kwikset.
Posted on May 18, 2013
SOURCE: lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Posted on Apr 24, 2008
SOURCE: Door deadlocks
take the lock apart & rotate the flat metal actuating rod 180 degrees & re-assemble the lock.
Posted on Oct 27, 2008
SOURCE: Just installed a Schlage secureKey
the first thing to check is to take the hardware off the door and check the lock cylinder with the key and make sure the key works the cylinder,, lots of times the tail piece is in the wrong position and will not allow the lock to turn. also - sometimes the latch and the lock are not lined up and bind, preventing the cylinder from turning.
but maybe the cyclinder itself is keyed wrong and if you take it back to the store where you bought it you should be able to swap it out for one that works,, install that one and all should be good.
c...
Posted on Jan 19, 2011
SOURCE: the key for my kwikset door handle lock won't
The answers to your problem are very numerous.
Usually what has happened is that when the lock was installed the pins (the part of the lock that rides on the cut part of the key) were not facing down. This allows dirt and debris to collect in the pin holes and also if a spring breaks it won't push the pin up to the cut part of the key. Some locks you can't even rotate to a position that faces down.
What I suggest is removing the knob or lever lock from the door and blowing out the key hole with compressed air. Work the key back and forth through the lock and blow it out again. If this doesn't work ... try and get a refund or a replacement from wherever you got it. Remember your time is worth money and so is your frustration. Don't waste allot of time trying to fix something that can be replaced relatively cheaply.
Thanks,
RSMITH972278
Posted on Oct 13, 2009
SOURCE: I installed new Quickset locksets
You want to loosen and take out the screws and remove the key side of the door handle and turn it 180 degrees and reinstall it. Now when you do this you will have to rotate the tang 180 degrees also so the inside lines up. The tang is that little bar that runs the length of the door handle.
Regards,
Tony
Posted on Apr 13, 2011
Jan 05, 2016 | 2005 BMW X5 3.0i
Apr 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Dec 14, 2010 | 2001 Volvo S80
Dec 12, 2010 | 2003 Mazda MPV
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Aug 21, 2009 | 1999 Porsche Boxster
May 15, 2009 | 2001 Cadillac DeVille
Nov 13, 2008 | 1995 Jeep Grand Cherokee
Aug 09, 2008 | Kia Rio Cars & Trucks
134 people viewed this question
