Question about Garden
Hose replacment for simoniz s1500 pressure washer
SOURCE: Simoniz S1400 Electric Pressure Washer
try momarch
Posted on Jul 01, 2008
  • 3 Answers
SOURCE: how to disconnect power hose from s2600 simoniz gas power washer
Just unscrew it like you would a garden hose and pull it out.
Posted on May 16, 2009
SOURCE: Simoniz pressure washer cycles whe not spraying?
This condition is normal.
Posted on Jul 02, 2009
SOURCE: Where is the pressure switch located on a simoniz
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Posted on Apr 29, 2010
SOURCE: I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Posted on May 02, 2010
No high pressure water
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jul 01, 2010 | Karcher 1550PSI Pressure Washer
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Aug 11, 2009 | Karcher Garden
No pressure on simoniz gas pressure washer
May 03, 2009 | Garden
How to disconnect power hose from s2600 simoniz gas power washer
Apr 24, 2009 | Honda Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
