Question about Disney Hannah Montana DVD Player
Player won't play certain dvd's
Any movies rated PG or PG 13 won't play.  A screen appears saying that the current parental setting won't allow it....... my wife and I do not real setting this nor do we know the code to enter to allow the movie to play.  Is there anything we can do or is our daughter only allowed to watch G rated movies on this player?
  • bestmatt62 Mar 12, 2009
    this is a Hannah Montana DVD player model # HM600D
The password is the arrows you have to do forwrd,backward,forward,backward but use the doubke arrow keys. this should work i found the soloution the manual
Posted on Mar 19, 2009
  • ctinaortizma Oct 08, 2010
    I love the internet-- thank you for posting the password!!! My kids are so happy!!
THAT WORKED FOR ME TOO!! Double keys, forward, backwar, forward, backward!!! THANKS!!!!
Posted on Mar 28, 2009
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
Password reset
The Rating menu allows you to block playback
of DVDs based on their ratings.
Setting the Password & Rating Level
The DVD player allows you to block playback
of inappropriate content with a passwordprotected
Rating system (not all discs are rated).
A. From Stop mode, press SETUP.
B. Select Rating and press ENTER.
C. Select Rating and press ENTER repeatedly to set the rating from 1 (most restrictive)
to 8( least restrictive ).
If a password has already been set, the lock icon will be closed. You will not be
able to select Rating until you SELECT the correct password using the 0-9 keys.
D. Select Password.
E. Use the 0-9 keys to SELECT a 4-digit password and press ENTER. The lock icon will
close to indicate that the rating and password are set.
F. Press SETUP to save and exit.
Not all DVDs are rated.
DVDs that are rated higher than the level you select will not play without SELECTING
the correct password.
If you forget your Rating password, select 8888 to clear the memory. Keep this password
out of reach of children as if will always unlock the Parental Control setting.
If you need more help you can get the full manual from
http://www.retrevo.com
Thanks for using fixya
Aug 01, 2009 | Astar DVD-3800
Parental lock
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
Apr 27, 2009 | KLH KD1220 DVD Player
Unable to get some NR movies to play even though I have unblocked NR material
The parental code is :
1,2,3,4
When the parental block comes up hit play, then type in the code and hit play again.  It should be all set.
Mar 28, 2008 | Disney Princess TV/DVD Combo
Parental code
You can take your time putting in the code. I mistakenly had the impression
you had to time it just right. But no.
Just close the tray with no disc inside, it will say NO DISC.
On the remote, press MENU, the "non-applicable" slash circle graphic comes
up.
Then press 1, (same slash circle), then press 9, and the menu pops up.
My menu says:
Region : 1
Password : ____
Level : 8. Adult
By default, the region number is highlighted. This is where I got confused. I
pressed the control pad on the remote left and right and up and down and
nothing changed the number.
The only way to change the number is to press ENTER on the remote and it
then cycles through all the numbers available. I was never given a chance to
punch in a number, I tried it and it didn't work.
While I was here, I also set my password code and looked through the choices
for LEVEL. I think it is a system to limit the type of movie that could be
played, for instance, if the DVD player was for a child's room, you could limit
the level to G, PG, or PG-13 and it wouldn't play movies rated worse than
that. good luck
please mark the post with a fixya!
Jan 22, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd will not play movies
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
Oct 20, 2007 | Disney 13" TV
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
Disney Hannah Montana DVD Player Logo
1,031 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
